Something burning?
Old Oct 23, 2016 | 07:23 AM
Quiettrain's Avatar
Quiettrain
Default Something burning?
I have an 06 DE that when I punch it, thers like some burning smell or something I can smell when I have my windows down. Then it goes away. Any thoughts. Smells like sulfer a little
Old Oct 23, 2016 | 07:33 AM
dkmura's Avatar
dkmura
General & DIY Moderator
Welcome and there could be any number of reasons behind the odor you smell. This is not a usual complaint with the Z. Could be a blockage in one of the catalytic converters, or a piece of debris caught between the undercarriage and a hot engine component. Have you jacked up the car to have a good look? Are there any codes in memory?
Old Oct 23, 2016 | 09:18 AM
chatcher's Avatar
chatcher
Look for valve cover gasket leak onto exhaust manifold.
Old Oct 23, 2016 | 09:39 AM
travlee's Avatar
travlee
Master
i guess actually opening the hood and looking around makes too much sense
Old Oct 23, 2016 | 03:42 PM
Quiettrain's Avatar
Quiettrain
Well I cant duplicate it while I'm parked. Its when I put it into overdrive
Old Oct 23, 2016 | 03:45 PM
nizmo_0385's Avatar
nizmo_0385
definitely your wallet dude. check your firefluid
Old Oct 23, 2016 | 03:46 PM
Quiettrain's Avatar
Quiettrain
Havent checked any codes. Just bought it so. Only does it when I hit overdrive on 75. Or pick up real fast
Old Oct 23, 2016 | 03:47 PM
Quiettrain's Avatar
Quiettrain
Someone said it was the sulfer in the gas down south?
Old Oct 23, 2016 | 03:48 PM
Quiettrain's Avatar
Quiettrain
Will definitely check that
Old Oct 23, 2016 | 03:55 PM
Quiettrain's Avatar
Quiettrain
Aaaahhhh! Sarcasm!.... The poor mans wit
Old Oct 23, 2016 | 07:33 PM
terrasmak's Avatar
Plastic bag on the y pipe
Old Oct 23, 2016 | 09:08 PM
dkmura's Avatar
dkmura
Your Z's diagnostic system will hold some codes in memory, so there could be a clue there. Not sure what you mean by "hit overdrive on 75"? Do you mean the odor only becomes noticeable when you shift into sixth gear at 75 MPH?
Old Oct 24, 2016 | 05:20 AM
TimsZee's Avatar
TimsZee
+1 on this.
