I cannot unlock the drivers door with the key
Old Oct 26, 2016 | 06:17 AM
Gee_Whiz's Avatar
Gee_Whiz
Default I cannot unlock the drivers door with the key
I am unable to unlock the drivers door manually using the key. The key goes in and turns just fine. I can operate the windows by turning the key, etc, I just cannot unlock the door no matter how hard I try to turn the key further. Any ideas what could cause this? Is it possible the physical connection between the cylinder and door lock inside the door could be disconnected? Any help is appreciated.
Old Oct 26, 2016 | 06:57 AM
MicVelo's Avatar
350Z/370Z Tech Moderator
Yes, entirely possible.
Any problems unlocking the car with the remote?
The door handle (and lock cylinder) are held on by just a couple of bolts on the inner edge of the door. Would suggest you remove (taking note of how everything goes back on) and check the lock cylinder. Usually a simple fix.
Old Oct 26, 2016 | 08:55 AM
rancor's Avatar
rancor
I though the door lock has a purely electrical connection to the locks. So if it opens and shuts the windows maybe it's the lock actuator. Does the key fob work?
Old Oct 26, 2016 | 09:03 AM
MicVelo's Avatar
Good call rancor. Been a bit since I took it off and changed mine. Just remember swapping the key cylinder onto new handle and now that you mention it, there is no physical link other than by wire or something.
Old Oct 26, 2016 | 01:29 PM
karlt's Avatar
karlt
I believe the driver's door lock using the key is mechanical, while hte passenger door lock is electric.
Old Oct 26, 2016 | 10:24 PM
CK_32's Avatar
CK_32
My pass doesn't even have a key slot
Old Oct 27, 2016 | 04:10 AM
The Swede's Avatar
The Swede
The driver door key/lock is mechanical. How else would you be able to get in the car with a flat battery (or without a battery, like I kept mine last winter)?
Old Oct 27, 2016 | 06:05 AM
rancor's Avatar
rancor
right it not like I've unlocked the car without a battery, multiple times.
Well then maybe ether the mechanical link came undone or the lock/handle is broken. I think you're just going to have to take the door apart and look for the issue. If you can unlock the door with the fob and interior handle it probably the exterior handle/link that's causing the problem.
Old Oct 27, 2016 | 06:11 AM
MicVelo's Avatar
right it not like I've unlocked the car without a battery mutiple times.
Oh, I see the issue. You guys don't have the Telekinesis Option on your Z's. That's why there's no physical link on mine. It was a pretty high cost option.
OK, fine. Oooops. Wasn't thinking. But how's that different from any other day?
Old Oct 27, 2016 | 11:04 PM
The Swede's Avatar
The Swede
Ye but how often do you have to refill your telekinesis fluid?
Old Oct 27, 2016 | 11:17 PM
bad boyz's Avatar
bad boyz
Gee,I'm having the same problem I researched it and found out you have to replace the handle a pretty simple fix,you can get the oem handle on Amazon shipped for about $75-80.00 there are a few good videos on youtube how to replace it.I heard it happens pretty often over time something Nissan went on the cheap side when designing it.
Old Oct 28, 2016 | 03:43 AM
Gee_Whiz's Avatar
Gee_Whiz
Everything else on the handle works. I can unlock via FOB, unlock from inside, operate the windows via the key. No issues opening the door. I just can't mechanically unlock the door. I found out because my battery recently died and I could not get into the vehicle. I ended up having to get a locksmith break into the vehicle so I could get in.
Old Oct 28, 2016 | 04:29 AM
ninevoltz's Avatar
ninevoltz
If you can open the door with the inside handle, the outside handle is broken. It's a common problem, I just replaced mine this week as a matter of fact. It's made of ABS plastic with knurled metal inserts. The inserts eventually break out of the plastic causing the outside handle to quit working.
Old Oct 28, 2016 | 04:32 AM
Gee_Whiz's Avatar
Gee_Whiz
I can open the door from the outside as long as the door is unlocked. My sole issue is the inability to mechanically unlock the door using the key. Wierd, right?
Old Oct 29, 2016 | 01:45 PM
Gee_Whiz's Avatar
Gee_Whiz
UPDATE: I pulled the door handle off and sure enough, the lock cable was not connected. Reconnected it and put the handle back on. I can lock and unlock the door now using the key! I wish all of my problems with this care was this easy to fix. Thanks for the help guys.
Old Oct 29, 2016 | 02:15 PM
MicVelo's Avatar
No problem, I just top it off with brannvin whenever I crack the Absolut.
Old trick I learned from having owned half a dozen Volvos.
