Headlights that are worth the money?
Old Nov 8, 2016 | 09:44 AM
Tekwhat's Avatar
Tekwhat
Originally Posted by Eigen
Have you adjusted your head-light beams? It is an easy job, all you need is a screwdriver.
The low-beams on my 04 were also terrible, however, I am came across a thread at one point about adjusting the beam angle higher and that really improved the lighting situation. They are far from being the best HID lights out there, but with the adjustment they are good enough for my needs.
I will update my post, if I find a link.
I will take a shot at that tonight, can't hurt.
Old Nov 8, 2016 | 09:47 AM
Eigen's Avatar
Eigen
If you haven't done it and it hasn't been done before (it looks like it hasn't from your video), it will be a noticeable difference.
I think I did three turns on my lights, night and day.
Old Nov 8, 2016 | 09:50 AM
Eigen's Avatar
Eigen
Here found you a link: http://www.350z-uk.com/topic/51852-h...ur-headlights/
Old Nov 9, 2016 | 07:47 AM
Tekwhat's Avatar
Tekwhat
I turned both of them about a hundred times, went up about 6 inches or so, two boards on the house.
I will know tonight how much it helped.
Old Nov 9, 2016 | 08:34 AM
CK_32's Avatar
CK_32
Well now your running into the risk of blinding or whiting out all on coming traffic.
Make sure your beam light cut off point isn't any more than 3ft off the ground pointed at a flat object roughly 25 ft ahead of you while your car is on a flat level surface.
Expect to get flashed by everyone on the road. I get people flashing me all the time in my truck after my level kit. And Ive already adjusted them to the proper height. But if your at the right angle my head lights will kill your eye *****. Feel bad for cars in front of me cause my lights are level with everyone's rear view mirrors lol
Does come in handy for the occasional d bag in traffic that cuts me off tho
Old Nov 10, 2016 | 05:54 AM
Tekwhat's Avatar
Tekwhat
Sorry about the shaky camera and it going out of focus near the end. Moving the lights up helped, but I think I'm going to still add a light bar. I've been doing some googling on it, and searched this forum, I haven't found any DIY guides for a z.
This light seems to have some good reviews, and its curved so should line up. Do you remove the grill so it's open to the radiator? or just put this behind it?
Old Nov 10, 2016 | 08:58 AM
imont's Avatar
imont
use a D2R bulb instead of the factory D2S . this gave me a lot more light with the factory 2003 headlight for little cost. the D2S has shields on the side of the bulb which in my opinion are stupid. You can also relay your high beams in order to use a 55w bulb. You can buy them on Rallylights.com. also wile relaying you can tie that light bar into your high beams. enjoy.
Old Nov 10, 2016 | 09:38 AM
Tekwhat's Avatar
Tekwhat
These are the lights I just ordered.
Low Beam High Beam
I would love to tie in the bar to the highs, but then I could never use my high beams until I was closer to home. I have a hour drive to and from work, 80% is in the country, but I often use the brights 99% of the drive. I think I'll put a switch in the panel on the left, where the gas lock is, I have a few free slots there.
Old Nov 10, 2016 | 09:44 AM
travlee's Avatar
travlee
Master
you are going to hate the 10k bulbs, it is going to be a very blue light and low output. 5o00k is almost pure white
although not the best pic, i have 6000k bulbs for headlights and driving lights, you can see some of the blueish from this pic
Old Nov 10, 2016 | 09:49 AM
MicVelo's Avatar
350Z/370Z Tech Moderator
Low Beam High Beam
10000K?! Oy.... cheap blue lights.
I thought you wanted MORE light.
So did you troubleshoot the rest of your system?
Old Nov 10, 2016 | 09:55 AM
CK_32's Avatar
CK_32
Yeaaaa do not go 10k...
Don't think it makes it brighter it just changes the color essentially. Btw I typically have run 7k on most of my sport bikes for visibility and it's usually a blue with a hint of white. 10k if not pure deep blue may be close to a purple in color. 12k is usually a full purple.
Color varies per application and company of bulb and ballast of course.
Old Nov 10, 2016 | 09:59 AM
Tekwhat's Avatar
Tekwhat
I haven't been able too yet. I am waiting on the new assemblies to come in, one has shipped, the other hasn't. Once I have them, I was going to test with the current lights in the new assemblies to see if there was a drastic difference. I did research AFTER buying those lights, 6000k is more what i'm after. They say that's close to daylight, my porch lights are LED's that claim daylight, it is such a pure light. For 10 bucks ill hold on to these, and get the 6000k ones.
What's in the car now are stock, so 4300k, they are so yellow and dim. The 10000k was an impulse buy because they were so cheap haha.
The assemblys are from here Left Right
Old Nov 10, 2016 | 10:06 AM
travlee's Avatar
travlee
Master
diode dynamics has and hid conversion
http://www.diodedynamics.com/store/l...conversion-kit
Old Nov 10, 2016 | 10:07 AM
travlee's Avatar
travlee
Master
if i remember i will take a pic of mine in the morning
**edit, found pic on computer. the left is 6k headlight and driving light. right is 5k headlight (i think), and 4300 driving light (corvette, not 350 though)
Old Nov 10, 2016 | 10:09 AM
Tekwhat's Avatar
Tekwhat
I thought all models but the base had HID already D2R (35W) - Xenon low-beam
H7 (55W) - High-beam
Old Nov 10, 2016 | 11:04 AM
CK_32's Avatar
CK_32
That is correct as far as I know.
Old Nov 10, 2016 | 01:43 PM
rancor's Avatar
rancor
Noon daylight is close to 5600K not 6500K as "daylight" leds often are. When buying lights look at the lumen output more than the color temperature.
http://www.morimotohid.com/component...tml?preselect=
Get some quality 4000-5000K bulbs
Old Nov 10, 2016 | 03:58 PM
  #38
MicVelo's Avatar
^^^ Totally THIS!
The "cheap aftermarket" (Hello, Fleabay?) people really do the enthusiast community a great disservice by advertising their "uber 10000K light bulbs for $5 a piece" and completely blow off the mention of actual light output (the lumens rancor mentions).
Higher color temperature numbers (the Kelvin number) are NOT always better and NOT brighter after a point reached on the color scale. (6000K or so is the cutoff then their output drops.)
Old Nov 10, 2016 | 04:54 PM
  #39
travlee's Avatar
travlee
Master
I noticed a decrease in light immediately in front of the car going to 6k, but reflective signs seem more noticeable with them....
Old Nov 11, 2016 | 06:19 AM
  #40
Tekwhat's Avatar
Tekwhat
I have also been looking at converting the high and low to LED lights, the Highs I can find the H7 and the resistor, but for the lows, i'm having a hard time finding a D2x type LED light to go in there. Have any of you gone this route?
