350z VDC Fuse
Old Feb 10, 2017 | 01:36 PM
Fridays_Ftw's Avatar
Fridays_Ftw
Smile 350z VDC Fuse
Hello all, first time poster. I have a 2004 350z and i just finished replacing my steering wheel. I removed the VDC fuse on accident thinking it was the horn relay and actually lost the fuse. I replaced it, and now the VDC light and SLIP light are on and the ABS seems to test itself every time I start my car and drive 10 feet, then it allows me to drive normal but the lights remain on. I removed the connection to the battery and made it again hoping that would reset everything but it didnt. Anyone have any idea what I can do? Thanks in advance.
Old Feb 10, 2017 | 02:40 PM
CK_32's Avatar
CK_32
Is it the right fine?
Don't mess with that IIRC that's also the fuze for your ABS system
Old Feb 11, 2017 | 06:49 AM
terrasmak's Avatar
Stock wheel or aftermarket ?
Old Feb 11, 2017 | 10:08 PM
i8acobra's Avatar
i8acobra
When you replaced the wheel, you may have moved the steering angle sensor. That will cause this. You'll need a scanner that can read steering angle and make sure it's at 0 degrees with the wheel straight up. If not, you either need to re-do the steering wheel install or do a steering angle sensor relearn with a Nissan Consult computer.
