Occasional Exhaust "Pop"
Old 06-20-2017, 10:49 AM
BigBlue
BigBlue's Avatar
Default Occasional Exhaust "Pop"
Howdy guys, I just had a question that some of you may relate to. I've had the sc kit on my car for 4 yrs. now and sometimes while shifting up a gear I get a "pop" out of my exhaust tips. It's not like an electrical issue backfire, actually sounds kind of cool when driving around town. Happens when clutch is depressed between gears.
It began once I went to sc; isn't a problem, but I wondered if any of you guys get an occasional pop sound when shifting? I have UpRev and my tuner's afr target now that it's supercharged is 11.5 at wot, which is the area that I currently hit so I should be good there.
My tune in map #1 pretty sure is stock timing. Map #2 he bumped the timing up slightly; #3 is slightly more advanced timing. *I've tried all 3 main maps and I can't tell any real difference from 1-3; none of the 3 seems better or worse regarding this issue or how the car runs.
I'm mostly in map 1 and 2. The car runs very strong and has zero hesitation, missing, etc. Always has pulled smooth and runs like a champ (both na/fi). I just wanted any feedback if possible about "if" the shifting pop from exhaust is normal, fine or not right. It seems to happen while under light/moderate acceleration say going from 1st to 2nd, 2nd to 3rd, maybe into 4th; doesn't seem to happen at higher speeds in higher gears. Thanks! *(supposed to hit 114 degrees today!).
KingBaby (06-20-2017)
Old 06-20-2017, 11:24 AM
bboypuertoroc
bboypuertoroc's Avatar
Received 2,446 Likes on 1,768 Posts
Just sounds like unburnt fuel igniting in your exhaust. Nothing to worry about.
The following 2 users liked this post by bboypuertoroc:
BigBlue (06-20-2017), KingBaby (06-20-2017)
