Idle drop at warm temp start up?
Old Jul 17, 2017 | 11:20 AM
Rashad92's Avatar
Rashad92
Default Idle drop at warm temp start up?
Hey guys, I have a 2008 HR 350z.
When I start my car once it's at operating temp. the idle dips to near stall (around 200 rpms) then goes back up to a steady 700-800 rpms. But the car drives fine and idles normally at lights. There are no CEL codes.
What could the problem be?
Old Jul 17, 2017 | 11:22 AM
travlee's Avatar
travlee
Master
have you done any PM on it?
Old Jul 17, 2017 | 11:26 AM
Rashad92's Avatar
Rashad92
Sorry i'm a noob lol, what do you mean by "PM"?
Old Jul 17, 2017 | 11:44 AM
rancor's Avatar
rancor
You need to do an idle air relearn. There is a way to do this with a pedal dance but the easiest solution is using NDSIII with a capable bluetooth reader.
Old Jul 17, 2017 | 11:56 AM
travlee's Avatar
travlee
Master
Preventative Maintenance
Old Jul 17, 2017 | 11:57 AM
travlee's Avatar
travlee
Master
he should do all of them honestly
Old Jul 17, 2017 | 12:03 PM
Rashad92's Avatar
Rashad92
I have not done that as of yet because I just wanted to know the main reason for the issue so I could just pinpoint the problem
Rashad92's Avatar
Rashad92
Thanks, I will try the idle relearn procedure and see if that fixes the issue.
Old Jul 17, 2017 | 12:08 PM
travlee's Avatar
travlee
Master
nobody will be able to diagnose your car from behind a keyboard.
Old Jul 17, 2017 | 12:15 PM
Rashad92's Avatar
Rashad92
LMFAO, while I do agree with that, I was just curious to see if anyone else has/had the same issue that i'm having. And it would be easier for me to troubleshoot the problems.
Old Jul 17, 2017 | 12:18 PM
travlee's Avatar
travlee
Master
there is a throttle position relearn that wouldnt hurt to be done, along with plugs, cleaning the MAF... but no matter what, NEVER TOUCH THE THROTTLE BODY BUTTERFLY
Old Jul 17, 2017 | 12:46 PM
Rashad92's Avatar
Rashad92
Thanks for the heads up. I originally assumed it would just need a MAF clean and a tune up. Might as well have everything done
Old Jul 17, 2017 | 03:46 PM
Atreyu'z 350's Avatar
Atreyu'z 350
lol.. classic.. and I've only been here 7mo
