Sponsored by:
Sponsored by:
Stock clutch with aftermarket flywheel??
Old 07-24-2017, 11:35 AM
FrozenAstronaut
FrozenAstronaut's Avatar
Default Stock clutch with aftermarket flywheel??
So i bought a brand new stock clutch for my standard 2003 350z. The clutch was originally slipping, and recently i found out that my flywheel can't be refurbished. Is there any way to place an aftermarket flywheel in conjunction with the stock clutch?? I'm trying to save as much money as possible, and can't afford the $900 on just the flywheel they're charging here. So if there are any cheaper that work well with what I got can you guys possibly send a link to some?
Old 07-24-2017, 11:57 AM
travlee
Master
travlee's Avatar
Received 9,058 Likes on 6,522 Posts
please dont double post
https://my350z.com/forum/2003-2009-n...-flywheel.html
return what you have and get the jwt combo from Z1, ZSpeed, or Concept z... will be $775 for both clutch and flywheel
Old 07-24-2017, 11:59 AM
travlee
Master
travlee's Avatar
in case you are too lazy to search
http://www.importpartspro.com/jwthdclco03n.html (they are in TX)
or since balla on a budget, get the z1 branded one
https://www.z1motorsports.com/z1-pro...bo-p-2405.html
Old 07-24-2017, 12:35 PM
icer5160
icer5160's Avatar
Be prepared for some gear lash chatter from the gearbox when you move to the Single Mass light weight flywheel (especially with the JWT unit). If you want to keep things quiet, spend the extra cash on the OEM dual mass flywheel.
-Icer
Old 07-24-2017, 01:19 PM
350Z/370Z Tech Moderator
MicVelo's Avatar
Received 3,261 Likes on 2,319 Posts
Sure, you can run a stock clutch with a SMF (single mass flywheel).
For stock like performance and lowest buy-in, suggest an iron FW like: https://conceptzperformance.com/jim-...de_p_19151.php
Or for a bit of performance (with a few small tradeoffs), a lightweight like this:
https://conceptzperformance.com/jim-...f000_p_322.php
Or: https://conceptzperformance.com/sout...-2a_p_9752.php
Shop any of the vendors supporting this site (I just happened to click on the above.) Prices will vary a little from vendor to vendor.
Old 07-24-2017, 08:25 PM
sauer420
sauer420's Avatar
-Icer
Yes, the JWT clutch/flywheel combo is annoying at idle. According to this recent review though, https://my350z.com/forum/2003-2009-n...ch-review.html, combining the JWT flywheel with the ZSpeed clutch got rid of a lot of that chatter noise. That'll be my next clutch.
Old 07-24-2017, 09:42 PM
MicVelo's Avatar
Key words on those last couple of warnings.... "light" and "weight". For that reason, chose the iron flywheel from JWT when replacing clutch on son's HR equipped car. The usual HR CD009 chatter did NOT get louder with this flywheel...quite the opposite actually, of what people complain about with lightweight flywheels (amongst the other negatives that to me, outweigh the benefits of going lightweight).
GrannySShifting
01-18-2017 06:41 AM
Logiqal
01-11-2017 07:18 AM
rocks
NA Builds
11-14-2016 05:29 PM
DaytonaBlueZ33
11-07-2016 04:10 AM
Quick Reply: Stock clutch with aftermarket flywheel??
