Brembo install
Old Jan 29, 2018 | 06:51 AM
That_hrz's Avatar
That_hrz
Default Brembo install
will be installing a set of oem brembos just want to clarify something's so I don't mess anything up. I'll be rebuilding them as well before install any advice helps!! What I've got so far
1. Remove or snip rear dust shields
2. Bleed system starting away from master
Old Jan 29, 2018 | 08:45 AM
GarniZ33's Avatar
GarniZ33
https://my350z.com/forum/brakes-and-...bo-brakes.html
/Thread
Old Jan 29, 2018 | 04:06 PM
dboyzalter's Avatar
dboyzalter
6 inch cawk is my fave!
Need new banjo bolts, or new lines.
Old Jan 30, 2018 | 07:46 AM
That_hrz's Avatar
That_hrz
Thanks very helpful
Old Jan 30, 2018 | 12:19 PM
icer5160's Avatar
icer5160
Pro-Tips:
Use some lug nuts on each corner to keep the brake rotors held firmly in place during the bleeding process, you don't want your rotors moving about while bleeding.
When you get to the bleeding process for the front Calipers, you will need to remove the upper caliper bolt and keep the lower bolt slightly loose. Also ensure you have some slack in your brake line. Then tilt the Caliper forward to put the bleeder valves as close to vertical as possible. This will help ensure all the air escapes from the caliper body during the bleed process. (Ask me how I discovered this).
The Brembo calipers in the rear use different Bolts, make sure you have those.
Each caliper has an inside and outside bleeder valve, always bleed the outside valve first and work your way to the inside.
If you're installing SS brake lines, make sure there's no rubbing issues with the lines when turning the wheel from lock to lock (or stop to stop). Re-route the lines as needed to ensure the brake line won't make contact with the rotor or wheel/tire.
Good Luck and have fun with the install!
-Icer
Old Jan 30, 2018 | 09:16 PM
CK_32's Avatar
CK_32
Yes.
midnight6
Brakes
15
Sep 1, 2013 03:22 PM
itsjiggajames
Southern California
Jul 22, 2011 04:05 PM
Vivid Racing
Apr 12, 2009 05:55 PM
HarvesterUT
May 26, 2005 11:49 AM
