2005 ROADSTER clutch in 2003 coupe
Old Mar 16, 2018 | 01:43 AM
jdm2003's Avatar
jdm2003
Default 2005 ROADSTER clutch in 2003 coupe
Can i put a 2005 ROADSTER clutch and fly wheel in a 2003 350z coupe??
dose any one know. or should i send the clutch back and get a correct one??
Thanks guys
Old Mar 16, 2018 | 03:01 AM
MicVelo's Avatar
350Z/370Z Tech Moderator
Thanks guys
No difference, yer good.
Old Mar 16, 2018 | 04:13 AM
jdm2003's Avatar
jdm2003
Ah good stuff... Thanks
Old Mar 16, 2018 | 11:59 AM
icer5160's Avatar
icer5160
I think the only difference for those years is the clutch fork pivot ball. Otherwise you're good to go. If you have a 2003, I highly recommend installing a beefier chromoly pivot ball, I recall that the 2003 pivot ***** were prone to failure due to their longer length and possibly under-engineered steel. In later years (2004+) the length was reduced to resolve the issue.
You can find chromoly replacements from all the major performance parts websites.
Good Luck and Have fun!
-Icer
Old Mar 19, 2018 | 03:31 AM
jdm2003's Avatar
jdm2003
-Icer
thank you.. i will replace the pivot ball components. I will have fun when ive done the clutch lol ...
Old Mar 19, 2018 | 05:50 AM
Atreyu'z 350's Avatar
Atreyu'z 350
https://conceptzperformance.com/czp-...100_p_3903.php
Old Mar 24, 2018 | 01:57 AM
Eigen's Avatar
Eigen
Another thing that changed in in 2004-5 ish, was the clutch fork. The older long pivot ***** mated with a weaker stamped steel fork. This was later upgraded to a stronger cast part which mates with the shorter pivot ball.
Found out the hard way, when I was doing my clutch...had the car on the stands for two weeks waiting for parts. As I decided to upgrade the fork after finding out.
That said, if all your replacing is the clutch you are good, make sure to replace the throw-out as well though. And if you have the long pivot ball, I would upgrade to a chromoly one just in case or go for the short pivot ball/upgraded fork combo....might as well if you have the trans off.
JoontheBaboon
Jan 11, 2009 02:26 AM
je350z
350Z Roadster
Apr 11, 2004 03:58 PM
