2003 touring
Old May 26, 2018 | 01:37 PM
Destintiger62's Avatar
Destintiger62
Default 2003 touring
My 2003 Touring keeps throwing code PO 300
Multiple cylinder misfire detected. I just had all new plugs put in. Mechanic check the voltage on the coils said they were all working fine. Service engine light comes on random and blinking. Car seems to run fine. Sonetines the car seems to have slight idle problem. Maybe mechanic missed diagnosed the coils. Open for suggestions. Thanks Chris
Old May 27, 2018 | 01:20 PM
tmdz's Avatar
tmdz
P0300 NISSAN - Cylinder Misfire Detected Random Cylinders
Possible causes:
Faulty spark plug
Faulty ignition coil
Clogged or faulty fuel injector
Intake air leak
Fuel injectors harness is open or shorted
Fuel Injectors circuit poor electrical connection
Ignition coils harness is open or shorted
Ignition coils circuit poor electrical connection
Insufficient cylinders compression
Incorrect fuel pressure
Read more: https://www.autocodes.com/p0300_nissan.html
350z plugs need to be gapped wider than many other vehicles. If your mechanic just threw them in without adjusting the gap that could be the culprit. Also leaks in the air intake system can happen if it’s not put back together properly.
I’d start there.
Zya27
Aug 12, 2014 01:19 PM
Sonoran
350Z Roadster
Feb 8, 2005 05:29 AM
NaK6iX
350Z Roadster
26
Feb 8, 2004 10:21 AM
supra crazy
Mar 11, 2003 03:29 PM
