Air Re-circle does not get tuned on....
Old Feb 20, 2004 | 10:32 PM
Mozi's Avatar
Mozi
Default Air Re-circle does not get tuned on....
...unless I have the A/C on. I am sure I am doing something wrong. So, if I am in "fan" mode, or any other than A/C, the re-circle light turns off and I start getting the fumes of other cars in my cockpit while in traffic
What's up??
MoZi
Old Feb 21, 2004 | 05:07 AM
azaz's Avatar
azaz
You are not doing anything wrong. That is the way the system operates.
The only way recirculate works is if the a/c is on. Sucks in a way but nothing wrong with your car or you.
Old Feb 21, 2004 | 05:27 AM
Mozi's Avatar
Mozi
Thanks azaz,
Ok, but I can't put recirculate even when the A/C is on and I want it on front Defrost / Defrog only. I can put recirculate if it is on front Defrost / Defrog AND leg vents open.
I don't know if I am being clear. Even when the A/C is on, I can't have recirculate AND front Defrost / Defog together.
How can I Defog in traffic without getting suffocated
MoZi
Old Feb 21, 2004 | 06:55 AM
specialp's Avatar
specialp
The controls can go on heat/recirculate provided you are not set on defog. Think about it, the object of defog is to get the moisture out of your car. if it recirculated, you would never be able to do this because you are circualting saturated air.
Old Feb 21, 2004 | 07:56 AM
Mozi's Avatar
Mozi
So I guess that is the way it is... Well, with other cars I' ve driven you can defog and re-circulate, together. Might not work optimally, but it makes an effect. I just can't fathom the idea of having a truck with his exhausts up my vents and I need to defog a little to be able to move forward. It means, I have to inhale his fumes, or not defog and be blind....
MoZi
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
2ndchanceZ
Oct 26, 2015 08:03 PM
KOF
Tuning
Sep 30, 2015 04:09 AM
