Cooling fan issue - Please Help!
Old May 31, 2019 | 08:26 AM
Chris Cannon's Avatar
Chris Cannon
Default Cooling fan issue - Please Help!
Hello All,
I purchased a 2003 350z and am having issues with the cooling fans.
I put new aftermarket fans on it and they turn on high & low only during the forced diagnostic test (key cycle & 10x door switch method)
The dash temp gauge appears to work correctly and even turning the AC on does not activate the fans.
Please let me know if you have any ideas or tips on what to check or how to fix.
Thank You!
Old May 31, 2019 | 12:07 PM
jellofuel's Avatar
jellofuel
I'd swap in stock fans, and see if that fixes it. Failing that, I'd inspect the relays, and check the voltage. What aftermarket fans did you buy?
Old Jun 4, 2019 | 12:27 PM
Chris Cannon
Thank you for the reply
They are Chinese oem replacement fans. They work when in test mode. High and low tests
When i check voltage on the fan plugs there is nothing unless i put it into test mode.
If the coolant sensor was faulty... would the dash gauge read correctly?
Edit*
Also i replaced all 3 relays and checked fuses
Old Jun 4, 2019 | 01:19 PM
tmdz's Avatar
tmdz
I remember reading somewhere that the Z fans always kick on when you turn on the ac. Not sure if that is correct but I can tell you that if you are trying to get the radiator bled it takes forever to get the things to cycle.
xxnismoxx
Nov 28, 2024 11:54 AM
Xrabbix
Jul 19, 2016 07:26 PM
The Fallen
Oct 1, 2010 08:22 PM
