JDM rev up engine? whats the word
Old Aug 7, 2019 | 03:24 PM
masterjr33's Avatar
masterjr33
Default JDM rev up engine? whats the word
hurt the motor in my 05 anniversary revup car.
locally here in town is a JDM engine depot and they have a few motors.
I did a JDM engine swap on the wifes subaru WRX
we took the JDM engine down to the long block. and swapped all the other parts back ffrom her car back onto the JDM block.
is this the same thing?
are they drop in complete? change some front drive? a few sensors?
Looking for advise. my other option is a LKQ or car-part engine used of unknown quality.
Old Aug 7, 2019 | 07:15 PM
rustyschopshop's Avatar
rustyschopshop
jdm is the same, i did manage to get an imported non rev up cheaper than any yard near me though with alot less miles.
Old Aug 8, 2019 | 04:32 AM
masterjr33's Avatar
masterjr33
Well i will be dealing with a rev up.
So basically pull my motor.
swap over the starter.
plug everything in?
any snags or gotchas ? fuel lines? or injectors or exhaust or anything.
any sensor issues?
Old Aug 8, 2019 | 11:35 AM
rustyschopshop
engine mount brackets were different but may be because it came from an auto. Also there is a sleeve in the crankshaft that will need to be pulled to install the pilot bearing. A pilot bearing puller on a slide hammer makes this easy. My engine didn't come with a starter so not really an issue. I don't remember anything else being different and not much should be. Only real difference from US spec and jdm is right hand drive. I did notice the partial harness that came with the engine was different but if you need replacement pigtails it is worth saving what you can.
Old Aug 9, 2019 | 08:56 AM
Desert Z's Avatar
Desert Z
Since it's a used motor do the gallery gasket if you are looking to drive this engine into the higher miles and or harder than usual.
brotherhef
Nov 9, 2008 08:56 AM
DuMa350z
Dec 22, 2007 08:23 AM
