P0303 Engine miss fire (not on z but G35)
Old 10-24-2019, 05:18 AM
CFAUVEL
CFAUVEL's Avatar
Default (FIXED) P0303 Engine miss fire (not on z but G35)
Sorry I know the car in question is not a 350z, but it is a 2005 g35 which has the same motor.
I just want to make sure I got my cylinder numbers right
passenger side cylinder numbers are 1,3,5
drivers side cylinder numbers are 2,4,6
Right?
so P0303 should be the middle cylinder on passenger side, right?
Old 10-24-2019, 07:06 AM
Heel Til I Die
Heel Til I Die's Avatar
Received 1,096 Likes on 776 Posts
Right?
Correct.
CFAUVEL (10-24-2019)
Old 10-24-2019, 08:34 AM
CFAUVEL
CFAUVEL's Avatar
Thanks mate
Old 10-24-2019, 01:17 PM
CFAUVEL
CFAUVEL's Avatar
So what is going on here?
What is shorting and why ? I imagine since it shorting there, I can just get a new boot and the coil is fine ?
Old 10-24-2019, 05:23 PM
Kevin Skene
Kevin Skene's Avatar
Could be a broken spring in the coil. Give replacing the boot a try and let us know!
Old 10-24-2019, 07:51 PM
CFAUVEL
CFAUVEL's Avatar
well I should have removed the coil BEFORE ordering the new coil (oem from amazon). The new coil did the trick of course. But I am going to buy just the boot to fix the old coil as I suspect it is still fine.
The little spring inside the old run is fine...not sure why the arc decided to find its way out of the boot the way it did.
Old 10-24-2019, 08:28 PM
rustyschopshop
rustyschopshop's Avatar
part of that boot that is dmg'd is phenolic plastic and plastic does crack over time. Plastic cracked and allowed spark leak burning the area and causing the miss.
CFAUVEL (10-25-2019)
Old 10-25-2019, 04:34 AM
CFAUVEL
CFAUVEL's Avatar
Thanks for the explanation, the coils are original soooooo.
going to buy a replacement boot and see if that works too, I suspect it will....thus I'll have a spare for either this car or my Z
Old 10-25-2019, 11:15 AM
rustyschopshop
Nothing wrong with keeping spare parts, never know when you are in a bind and need a replacement. Spares can also be nice for diagnostic purposes.
nissan350zca
01-20-2017 08:01 AM
citlali.dp96
10-04-2016 03:16 PM
Street Visionz, Inc.
12-10-2003 07:47 PM
Quick Reply: P0303 Engine miss fire (not on z but G35)
