Help needed! Coil boots stuck...
Old Feb 28, 2020 | 06:35 PM
dustynb23's Avatar
dustynb23
Default Help needed! Coil boots stuck...
Anyone ever have this issue before?
Old Feb 29, 2020 | 04:17 AM
813_350Z's Avatar
813_350Z
What have you tried so far?
Old Feb 29, 2020 | 04:51 PM
dustynb23's Avatar
dustynb23
I got them out with a pair of pliers. However, when reinstalling the valve cover bolts the bolts keep snapping with barley any pressure on them... Have gotten 3 bolts stuck so far. Yes I’m doing it in order and putting them to 15 ft lb. or torque and they continue to snap..
Old Feb 29, 2020 | 06:20 PM
813_350Z's Avatar
813_350Z
That's your problem. You are over-tightening them. The specs state INCH-LBS, not ft-lbs. 15 ft-lbs is equivalent to 180 inch-lbs. For comparison, the top nut of your motor mount is torqued to 26ft lbs. You are torquing bolts holding your engine cover to 10 lbs less than you'd torque a nut holding your engine in place.
Here are the correct specs below
BlueCheeZe
Oct 21, 2015 06:26 AM
DaveFunction2ND
Mid-Atlantic
Jul 2, 2009 04:26 PM
ADMAN
Jan 7, 2009 02:25 PM
ycdevil
May 23, 2008 10:05 AM
