Anyone have the Z1 upper A arms?
As titled I'm trying to get some info on the adjustable Z1 upper control arms. Found out mine are squeaking. I lubed em up but that only a temporary fix.
I see they have that offset ball joint for extra caster. Which has been my #1 complaint with this car from the beginning, lack of caster. There is no weight in the steering wheel.
Does anyone have them who can tell me how they feel the steering has changed after the arm install? Any info will be appreciated. Thanks guys.
I found other arms from Australia that come with shims allowing you to move the caster +/- 1 degree. A whole degree of caster can make it feel like a whole new car. Think the difference between a miata's steering feel and a Porsche. It's drastic. I love caster. I am also a big guy so the extra steering weight doesn't make it too hard to turn the wheel. For a 110 woman, maybe
The Z1 arms claim their ball joint is more offset than stock.
Then there is thing company which uses shims on the mounting points to move them further forwards/backwards for +/-1 degree of caster change.
The only thing I know for sure is moving the mounting points forward or back is exactly how my brother in law did it to change caster on his trophy truck.
Technically as long as that ball joint moves forward should all do the same thing.
Thoughts?
That Australian company also has some lower control arms they claim change caster even more. By 2 or 3 degrees. Seems like a serious amount to mess with caster
If you run their race upper with heims for the inner pivots instead of bushings you can adjust the caster a little by threading one side in more than the other. The heims don't have high misalignment spacers, so you won't be able to get much but it might be enough to change your steering feel. For what it's worth I have Z1 race uppers and my steering is heavy as hell, though that could be my steam roller 285s up front. I can't remember my caster setting off the top of my head, but the steering feel is great.
The Z1 arms will work... but your alignment guy is going to want to punch you in the face. The pivot bolts or ball joint have to be removed to make adjustments.
I pulled the trigger on the GKtech ones that adjust the caster with the spacer. As far as camber goes, honestly, I think I'm just going to set up the arm the same length as the OEM ones and the just turn them equally like 4-5 times.
That should leave me with about 1.8 degrees of camber in the front. Combined with the increased camber I will gain in corners with the extra caster I think that should decrease my understeer somewhat.
Its not really going to be possible to align it perfect side to side for cambe rim the front. Since I have OEM springs on Bilstiens you have to literally take the strut out to get the arms off to adjust the upper arms. No alignment guy is going to go through that. And if they would, they would charge me a million bucks to do it lol. A couple points of a degree difference isn't going to hurt anything
venture210
Suspension
05-03-2017 06:34 PM
