Z won’t crank 2006 6mt
350z not cranking.
Ok I have a 2006 350z 6 speed manual transmission .
Battery is fine, fuel pump is fine.
Left this morning to go put some gas in and came back to the house to get ready. Went back to the car to head to town and it won’t crank.
Engaged clutch tried to turn the ignition and nothing. No crank no nothing. It’s almost as if I’m not engaging my clutch and trying to start the car.
Havnt has a chance to push start it yet. Any ideas before I start tearing into this car?
Make sure your clutch pedal switch is actually working and where it should be. Could be something as simple as that. Also make sure you're using the master key, not a valet key. I've heard of the anti-theft system kicking in if the valet key is used too often.
-Icer
-Icer
Frankrod214
Jun 20, 2019 05:35 AM
