lowering springs and camber arms
Old Jan 13, 2021 | 12:04 AM
Rick_Sancheese's Avatar
Rick_Sancheese
Default lowering springs and camber arms
Hi, Im looking to get some eibach sportline springs for my Z, I know lowering springs arent the best way to lower a car but its too hold over until I get bag money. I wanted to see if anyone runs these springs and is there any camber issues, I also am thinking about getting spacers with the springs but if the fitment is too hard to get then Im ok with just the springs and camber arms if I need them.
Old Jan 13, 2021 | 10:19 AM
DarkZ03's Avatar
DarkZ03
Nothing wrong with springs at all, that's an old notion, as long as they a matched with good shocks you are good.
Old Jan 13, 2021 | 11:07 AM
travlee's Avatar
travlee
Master
I ran prokit and d-specs, loved that setup
Please tell me you aren't going to be one of the camber gang retards
Old Jan 13, 2021 | 11:22 AM
Rick_Sancheese
No I just wanted to see if I use 30mm spacers and the sport line kit would I need to use a camber kit
Old Jan 13, 2021 | 11:26 AM
travlee's Avatar
travlee
Master
Why spacers
Old Jan 13, 2021 | 01:52 PM
Rick_Sancheese
Why spacers
just looking to get my stock wheels flush with the body
Old Jan 13, 2021 | 02:05 PM
MicVelo's Avatar
350Z/370Z Tech Moderator
Oh, WHEEL spacers.... Thought you were referring to spring spacers and its effect on camber (by raising the car back up).
That said, wheel spacers are irrelevant to the need to correct camber and toe.
Generally speaking, lowering the car more than about 25mm will change camber and toe enough to warrant correction through adjustable camber arms in back, FUCA in front, and rear offset bushing or toe arms (if true coilover with removal of spring bucket).
Eibach Sportlines will lower a Z more than 25mm, so for the sake of your tires, recommend adding the adjustables mentioned.
iceman09
Suspension
Aug 20, 2015 11:28 AM
XSpeedAddictX
Suspension
Oct 30, 2011 09:31 PM
djcarmine723
Apr 4, 2009 09:40 PM
vbgambini
Aug 21, 2008 08:05 AM
guzzie23
Jun 24, 2008 10:36 AM
