Tire/Wheel combo
Old 05-07-2021, 08:03 AM
SnaykeByte
SnaykeByte's Avatar
Question Tire/Wheel combo
I'm new to the forum as well as a new 350Z owner. It is a 2006 base 6 speed with a DE and is on factory wheels and skins, staggered. I want to go square with 18x10's with 275/35's all around. I'm thinking +15 on all 4 corners. Not really wanting to get into a roll or pull right now and was hoping I could get away with this setup with no interference issues. Whuddaya think??..............-Curtis
Old 05-07-2021, 11:30 AM
Blurvision
Blurvision's Avatar
18x10.5 +15 will work perfect
Old 05-07-2021, 12:24 PM
Bak3rme
Bak3rme's Avatar
wheel/tire setup will work at stock height. Front might rub under compression.
I've used 2 different 275/35/18 tire sizes and they don't come the same width. Had federal RSRR and falken RT615K+ both in those sizes and federals was more bubble whereas falkens were slightly stretched.
Old 05-07-2021, 12:34 PM
SnaykeByte
SnaykeByte's Avatar
I preciate the input fellas.
Old 05-07-2021, 12:51 PM
SnaykeByte
SnaykeByte's Avatar
Ok, update. Just found a good deal on some 285,s...........can I squeak by with those?
Old 05-07-2021, 03:16 PM
zwei_the_c
zwei_the_c's Avatar
I'm not sure about the fronts myself, I think it would barely clear with some rubs. I have 275/35 up front with no issues so another 10 might not hurt. As for the rears, you should be fine but I did have my quarter rolled only. I think you may have to roll them. It would
It would help to say what sidewall and what kind of tire, 40? I don't think so. 35, I think you will be OK. Some tire run wider than others. So if it's an Hankook brand, you'll be fine. If it's a Federal brand, then it's runs more like a 295 which may not fit.
Old 05-12-2021, 11:53 AM
SnaykeByte
SnaykeByte's Avatar
From your input, I think I'm gonna go with the 275/35/18's.
Gregrezz
03-06-2013 05:51 PM
Germanguy
04-06-2009 10:31 AM
driverx2010
03-22-2009 04:08 PM
GA_VQ
03-31-2008 02:28 PM
Quick Reply: Tire/Wheel combo
