Multi-cylinder Misfire
Old 10-28-2021, 10:43 AM
Frankieramsook
Frankieramsook's Avatar
Default Multi-cylinder Misfire
03-350z. Good compression, good spark, good fuel. Misfires on cylinder 4 and 6. It has new plugs, new coils, new injectors, new intake manifold and gaskets, new valve cover and gaskets, new fuel pump. Would like any suggestions. Thank you.
Old 10-28-2021, 10:47 AM
350Z/370Z Tech Moderator
MicVelo's Avatar
Received 3,285 Likes on 2,337 Posts
Double check that the 4 and 6 wires aren't crossed. Very common due to the proximity of one another.
jv350z (10-28-2021)
Old 10-30-2021, 02:31 AM
Jim Stephens
Jim Stephens's Avatar
Could also be a vacuum leak. Check two things. Check to ensure all of the hoses are connected to the plenum. Run you fingers around the edges of the plenum and see if you hear or feel any leaks. Another way to do it is to take some saran wrap and put pieces around the plenum edges and then start up the engine. If it then runs well remove one piece at a time until it starts to misfire again. This will help you find the leak. I personally have experienced this problem of the misfire and it was caused by air being sucked in the plenum area (in my case I Missed a vacuum hose). Sometimes you can catch the rubber edging around the oil filler between the plenum halves. Watch this video until the end.
MicVelo (10-30-2021)
Lawn Dart
07-17-2017 09:39 PM
BMGz33
05-23-2017 12:58 PM
ATIX
09-13-2016 05:46 PM
Supertouring
11-19-2013 09:59 AM
Quick Reply: Multi-cylinder Misfire
