07 350z HR P0345, P0643 code
Old Apr 7, 2022 | 07:59 PM
07Z_Bryan's Avatar
07Z_Bryan
Default 07 350z HR P0345, P0643 code
What’s up guys I got a 07 HR MT recently put ISR LTH and had a coworker make me extension harness for the O2 sensor and got the codes p0345, p0643 car was running great (tuned by LMT) I was doing a pull car started cutting at 7k rpm switched gears kept pulling hard but stopped again at 7k then SES light came on then car started to misfire swapped out both bank 2 cam position sensors with AutoZone ones car ran great again but still cutting me at 7k then went into limpmode what can be my issue? One of the wires from the O2 sensor was spliced n just put together without soddering it but it’s in the connector
Old Apr 8, 2022 | 05:32 AM
i8acobra's Avatar
i8acobra
Sounds like your guy wired your extension incorrectly. P0643 means there's 12V on a 5V circuit. He probably attached a heater circuit wire to the sensor wire by accident.
Old Apr 8, 2022 | 08:57 AM
07Z_Bryan's Avatar
07Z_Bryan
wouldn’t it throw a code for the O2 sensor then? But ima order a extension harness see if that’ll fix the issue because everything seems to be pinned correctly… do you happen to have a pin diagram for the connector?
Old Apr 8, 2022 | 12:58 PM
i8acobra's Avatar
i8acobra
Either that or there's an issue with your cam sensor harness. One of your 5V sensors is seeing battery voltage.
Old Apr 23, 2022 | 09:38 AM
07Z_Bryan's Avatar
07Z_Bryan
Issue ended up being ther aftermarket cam sensors from AutoZone where the p0345 code but the p0643 code I’m assuming has to do with my bank 1 o2 sensor harness from the engine side it was cut and taped together so I’m hoping that’s the issue
03stampededak
Mar 18, 2019 10:13 AM
LOADED
Mar 19, 2016 12:13 PM
saechao916
Aug 12, 2014 09:45 AM
Zomgfast123
Jan 12, 2010 04:29 PM
JWS82
North West
20
May 6, 2009 07:54 PM
