2005 350z Enthusiast Copart Build
Old Apr 29, 2022 | 05:34 PM
cajuncustom's Avatar
cajuncustom
Default 2005 350z Enthusiast Copart Build
This Is The 2005 Flood Car i am building 151220 miles , the car sat in my back yard for 2 years , in that time the dogs thought the wiring harness was a chew toy , when we went to move it we seen a rat the size of a buick run out from under it babys in tow , so this car was stripped for the other 350 , it cost 1650 but the cost was absorbed into the cost of the 2004.Yes it was a flood car but had 0 signs of it.
im still at this point working on it with a miss problem , im getting help with that from James here on the forums , so this is a long list of parts i have into this car , the rims and tires are more of a want then a need as you will see a few other parts but here is the list , not including the bumper im getting ready to order tonight.
The exhaust i had to change because when i was reving it up half a persian rug and a tree fulla nuts came out the exhaust so i figured it was plugged , after taking it off i found the drivers side cat was shot.
Quick lesson when people say dont buy cheap sensors and stuff LISTEN as you can see i bought some multiple times because i bought cheap ones
amazon some stuff i didnt remember so its just the prices
233.09
86.14
86.72
133.07
96.69
6.59
z1 - uprev nat delete - 509.50 - had to Nat delete because the car did not have a chiped key with it
z1 bumper support brackets / hi flow intake - 353.18
$26.00 pull a part
13.84 - amazon remotes
9.22 - amazon pvc valve
43.99 amazon 02 sensors
50.33 facebook airbag - refunded never shipped
110 facebook airbag cover
337.57 z1silicone hose kit
29.69 amazon sensors
40.39 orielly brakes front
48.50 - ebay - Valve Timing Control Solenoid
518.81 amazon
88.00 ebay seatbelt
47.17 - z1 - VVT Gasket
140.66 amazon , hatch shocks , headlights and tail lights , antenna
29.69 oil catch can amazon
13.00 target tire fix tire
272.74 z1 transmission oil cooler , bleeder , hose
61.00 lug nuts - Fitment ind
20.00 nissan - radiator mount bushing
59.99 airbag reset
10.00 shipping
21.99 headlight harness
183.33 gaskets knock sensor
25.86 horn relay / injector connectors
49.48 pcv valve
22.00 clock spring
118.80 air bag
727.90 carbon fiber pillars
70.99 door pull
114.82 pillar rubber and clips , rgb rocklights
416.22 ebay spec d exhaust
241.00 ebay Beluga Racing Resonated Front Pipes
162.11 ebay Hitachi Cam Crank Sensors
43.21 z1 injector sub harness
5582.06
$2,444.68 Fitment Industries
(2) DS21911511415VG Aodhan DS02 19x9.5 +22mm
(2) DS21995511422VG Aodhan DS02 19x11 +15mm
(2) 841623100612 Delinte 245/40ZR19
(2) 841623100674 Delinte 275/35ZR19
cajuncustom
Apr 10, 2022 05:19 AM
thespottedcow
Cooling System
Feb 13, 2018 05:30 AM
350niZmo
Aug 12, 2016 08:41 AM
805350z
Jul 20, 2013 11:52 PM
16psibrick
Jan 12, 2007 01:29 PM
