Manual 350 hard to put in gear
Old Oct 2, 2022 | 01:18 PM
Cunningline70's Avatar
Cunningline70
Default Manual 350 hard to put in gear
Hello, ive looked through the forums and havent found anything that might help me so heres my problem. My 2005 350z track is very difficult to get into 1st or reverse upon cold start, then when i get some heat in the car it again struggles to go into 1st at stop lights and such. Ive already replaced the tranny fluid with redline fluid and did a z1 clutch kit job a while back. Clutch fluid is dirty but is full. Other than replacing the clutch fluid does anybody have suggestions. Maybe my slave cyl?
Old Oct 2, 2022 | 03:04 PM
MicVelo's Avatar
350Z/370Z Tech Moderator
Since you had to have the trans out to do the clutch, try a shift plate alignment.
https://my350z.com/forum/engine-driv...alignment.html
https://my350z.com/forum/maintenance...alignment.html
And many more....
Old Oct 2, 2022 | 03:17 PM
Cunningline70
And many more....
I will Readjust it however i dont think thats the problem due to it not being difficult all of the time if that makes sense. Thank you for the response.
Old Oct 3, 2022 | 07:22 AM
iideadeyeii's Avatar
iideadeyeii
Sounds like it's not fully disengaging. If this is true it should go into 1st/rev when the car is off easily.
Could be slave, could be clutch master. Bleed it and go from there
Old Oct 3, 2022 | 08:39 AM
Cunningline70
will do, thank you for the response!
Old Oct 4, 2022 | 04:44 PM
icer5160's Avatar
icer5160
I had a similar issue with my Z years ago after I replaced the Master and Slave cylinders. Even though I bled the system a lot, it wasn't enough. I continued to have difficulty shifting into 1st gear. After a few weeks, I bled the clutch hydraulics again and still got some air bubbles out. That second bleed resolved my issue. In your case, I would look for leaks at the cylinders and since the fluid is black/dark, I would flush it. The parts aren't very expensive, if they are the original cylinders, it couldn't hurt to replace them.
-Icer
Old Oct 18, 2022 | 05:41 PM
Cunningline70
-Icer
hello, i have replaced my slave cyl and replaced my old fluid. Left old master cyl because it wasnt leaking. Have bled the system so many times with multiple different methods and the clutch pedal has never felt stiffer however the problem still remains. Im unsure of what to do next. I think im gonna try to throw my stock flywheel and clutch back in it to see if that changes anything. I dont have the money to keep throwing new parts at it atm so i dont have any more ideas. Your thoughts?
Old Oct 19, 2022 | 05:12 AM
iideadeyeii
Look though the boot of the fork and see if your pressure plate fingers are janked up.
Also, get underneath and have someone press and hold the pedal and see if it holds and doesn't slowly retract
Old Oct 19, 2022 | 07:04 AM
Cunningline70
ill do that today thank you.
Old Oct 19, 2022 | 02:10 PM
Cunningline70
everything looked good, im pulling the tranny this weekend. Gonna put oem clutch **** back in it and hope for the best. Any other ideas?
Old Oct 19, 2022 | 04:03 PM
icer5160's Avatar
icer5160
Double check your clutch pedal linkage to the master cylinder shaft, make sure the clevis fork with the jam nut is properly setup. The only thing else that comes to mind for me is making sure you have the correct Clutch Fork and Pivot ball combo. Also make sure your throwout bearing is properly installed on the carrier. Since this issue is only impacting 1st and reverse on cold start, I doubt you have a problem with these components, but since you're pulling the trans, it's worth inspecting and re-greasing at the very least.
It wouldn't hurt to measure the spacing of the new vs. OEM flywheel and pressure plate combos. See if there's a noticeable difference between them, they should be the same.
Good Luck!
Old Oct 19, 2022 | 04:13 PM
Cunningline70
Good Luck!
meant to update but its not just on cold start anymore, its gotten worse but i will look into what you said. I really appreciate it.
Old Oct 20, 2022 | 05:32 AM
iideadeyeii
I bought an ebay 14lb lightweight flywheel and ebay clutchmaxx for my car. Cost about $310 shipped. Working well so far for the past year(flywheel is new this year, but clutch was form last year). Might be something you should look into
Old Oct 23, 2022 | 08:40 PM
thebomb2644's Avatar
thebomb2644
Going with a new shifter assembly linkage just ordered from conceptz. I've tried it all, new cd9, new clutch, name it...I've replaced it. Can't move into gears with engine off, completely locked out it only let's me shift when the engine is on and spinning the gears
Old Oct 24, 2022 | 03:33 AM
travlee's Avatar
travlee
Master
bb17
Oct 19, 2022 02:16 PM
Evenflow80
Apr 30, 2019 12:13 PM
Kcee91
NISMO 350Z
25
Jul 3, 2011 11:40 AM
astley101
Apr 10, 2008 11:01 AM
