Stripped strut brace bolt holes
Old 10-12-2022, 04:35 PM
gradyshock
gradyshock's Avatar
Default Stripped strut brace bolt holes
Hello,
My daughter bought a 2006 350Z with two of the strut brace bolt hole stripped out. Is there enough meat there to tap it to the next size up?
Old 10-12-2022, 06:24 PM
350Z/370Z Tech Moderator
MicVelo's Avatar
Received 3,285 Likes on 2,337 Posts
Should be plenty of meat there.
If not, just helicoil it. There’s some lateral loading under cornering but a helicoil will be fine.
Old 10-12-2022, 06:29 PM
gradyshock
gradyshock's Avatar
Thanks, the original size is m10x1.25 correct?
Old 10-13-2022, 05:21 AM
iideadeyeii
iideadeyeii's Avatar
Can you get a longer bolt and a nut underneath?
Old 10-13-2022, 10:17 AM
gradyshock
gradyshock's Avatar
Probably could but that seems like a worse solution than re tapping
Old 10-13-2022, 11:39 AM
iideadeyeii
Here's another solution, put a bolt through the bottom and a nut on the top
Old 10-13-2022, 12:40 PM
MicVelo's Avatar
Sorry, I personally can't confirm that but it sounds right. This thread seems to confirm it.
Old 10-14-2022, 05:20 AM
Heel Til I Die
Heel Til I Die's Avatar
Received 1,096 Likes on 776 Posts
M10x1.25 is correct. A helicoil or some other type of threaded insert or threaded bushing should work.
When I did my plenum spacer, I had to raise my strut bar a little so it wouldn't make contact with the top of the plenum. I went with M10 x 1.25 x 30mm, so I would imagine the stock length is shorter than 30mm. Maybe 25mm?
Old 10-14-2022, 03:09 PM
icer5160
icer5160's Avatar
Yes, M10x1.25 is commonly used all over these Zs (exhaust flange bolts, strut shafts for upper mounts, the upper front tower brace, and many other locations). I made an oopsie on the Z once and had to find a tap and die set with this size, it was not easy finding a local shop that had tools in this size. The more common pitch is 1.0 or 1.5, not very many 1.25s, guess it's a Domestic thing?
Cheers!
-Icer
pfregeolle
03-20-2013 09:13 AM
OffsetZ33
04-10-2011 10:48 AM
blackfairlady
02-04-2008 04:48 PM
Barzten1
11-02-2005 05:08 PM
vice86
08-11-2003 09:07 AM
Quick Reply: Stripped strut brace bolt holes
