Minor Upgrades
Hello, all.
Yes, brand new to the forum. My apologies if this is not in the correct location.
My 08' couple just hit 100K, and I've decided to update some things.
The K&N dual intake finally arrived (back ordered 6 months), but I felt I should also update the spark plugs and coils. I'm looking at NGK iridium plugs with Heat Range #8. And I'm looking at Hitachi Ignition Coils for the VQ35HR. Currently about $82 from Concept Z.
Any feedback is appreciated. didn't know if anyone had experience with these or not.
Thank you in advance!
Welcome to the forum.
Plugs you should be able to inspect to see whether they're in need of replacement (standard heat range unless you're pushing more power) and I wouldn't touch the coil packs unless there were signs one was going bad. And then I would only replace that one. They're more typically going to be either good or bad, not somewhere in between.
