Pulstar plugs
Old Aug 31, 2013 | 09:01 AM
Larry Hargrove's Avatar
Larry Hargrove
Default Pulstar plugs
I've seen ads claiming 12% hp increase with these Pulstar plugs as well as increased mpg. Anybody here have any experience with these?
Old Aug 31, 2013 | 09:05 AM
dcains's Avatar
dcains
It's true - they're magic.
Really, just get yourself some OEM plugs and call it a day.
Old Aug 31, 2013 | 09:48 AM
Flick Montana's Avatar
Flick Montana
Compare to what? Spark plugs made of bacon?
Old Aug 31, 2013 | 09:52 AM
dcains's Avatar
dcains
Old Aug 31, 2013 | 09:58 AM
zach711f's Avatar
zach711f
hahqaah
Old Aug 31, 2013 | 10:39 AM
2004Black350z's Avatar
2004Black350z
Exhaust Whore
Be the test mule. Back to back dyno. If it works im installing 12 of them
Old Aug 31, 2013 | 11:41 AM
RedScytheZ's Avatar
RedScytheZ
Want to buy some snake oil too? It'll give you untold fortune, cure cancer and diabetes.
Old Aug 31, 2013 | 04:18 PM
superlim9's Avatar
superlim9
Search....
https://my350z.com/forum/engine-and-...n-results.html
found in two seconds... from 08 when they came out... with dyno.
good luck getting a full set that works on the first try had a lot of issues with quality control/shipping damage
Modified Mag got +10 whp on best run on an 06 rev-up... 12% is utter BS though... most tests show maybe 5-6% on best run but dont say what else was changed on the car.
but not worth the 20$ a plug. just buy 'em and do a proper dyno comparison to see
Old Aug 31, 2013 | 08:21 PM
WSchli1672's Avatar
WSchli1672
Not worth it... plain and simple, the cost is way over the return.
Old Sep 1, 2013 | 12:21 PM
Larry Hargrove
I thought that sounded too good to be true. After checking under the hood I'm not sure that I want to put any plugs in it. Maybe the ones in it will last forever. HaHa
Old Sep 1, 2013 | 12:27 PM
waldo36's Avatar
waldo36
From what I was told when considering these plugs, apparently the OE plugs are rated at 100,000 miles before needing to be changed.
Old Sep 1, 2013 | 04:06 PM
Larry Hargrove
My '04 now has just over 101,000 on it. I bought it used so it's probably a good bet that they need to be changed. Is changing them as hard as it looks? I can barely see the ones on the driver's side.
burglapfd
Dec 6, 2020 01:04 PM
350z82
Oct 1, 2015 06:25 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
35reilly
Sep 28, 2015 07:42 AM
