350z brake fluid reservoir sensor.
Old Jan 30, 2023 | 12:45 AM
Billyt858's Avatar
Billyt858
Default 350z brake fluid reservoir sensor.
How do you remove it?
How do you remove the fluid level sensor? Or do you have to replace the whole reservoir?
Old Jan 30, 2023 | 01:44 PM
icer5160's Avatar
icer5160
You don't. It's embedded in the reservoir. You might be able to purchase a new reservoir with the sensor, but typically if something goes wrong with these, you just replace the whole master cylinder as a complete unit. Taking this apart to rebuild them often results in failure and leaks. Just better to purchase a whole new OEM unit, they aren't very expensive.
Cheers!
-Icer
Old Jan 30, 2023 | 08:06 PM
Billyt858's Avatar
Billyt858
I was able to remove it. Will purchase a new fluid reservoir sensor to replace it with.
Old Jan 31, 2023 | 11:24 AM
icer5160's Avatar
icer5160
Hi Billy,
You removed just the sensor or the entire reservoir? I hope all goes well with the install of the new reservoir/sensor.
Cheers!
-Mark
dklau33
Jan 30, 2023 05:52 AM
Jason14227
Sep 21, 2017 11:06 AM
zswickliffe
Oct 10, 2014 06:43 PM
skeetzee
Apr 16, 2013 02:21 PM
DaytonaRoadster
Apr 7, 2008 06:42 PM
