2003 brembo calipers
Old Feb 4, 2023 | 04:34 AM
Datzxjr's Avatar
Datzxjr
Default 2003 brembo calipers
I have a 2003 Touring model, can I swap out the OE calipers (and rotors/pads) to the Brembo track calipers/rotors with the stock 17" wheels? will they bolt on or will i need adapter brackets? I looked into the Akebono calipers but looks like they might not fit with the stock wheels plus i would need brackets.
Also are the rear Brembo calipers 1 piston or 2 piston?
Old Feb 4, 2023 | 04:37 AM
Datzxjr's Avatar
Datzxjr
Nevermind, search function does work! lol
DIY for stock non-Brembo to stock Brembo brakes - MY350Z.COM - Nissan 350Z and 370Z Forum Discussion
Old Feb 6, 2023 | 06:17 AM
iideadeyeii's Avatar
iideadeyeii
I posted a pic in one of the discussions regarding big brakes with all the part numbers to get these remaned from rockauto. Was about $600 for the front and rear I believe with lines and rotors
Old Feb 6, 2023 | 08:31 AM
Datzxjr's Avatar
Datzxjr
I just placed an order from Rockauto like 30mins ago! lol they had a complete kit (front 4 piston, rear 2 piston, F&R plain rotors, Powerstop ceramic pads and hardware minus the brake lines for for around $1000. I'll order the SS lines from Z1.
Old Feb 6, 2023 | 05:42 PM
icer5160's Avatar
icer5160
Don't forget you will need replacement bolts unique to the Brembo's for the rear calipers. The non-brembo bolts cannot be re-used for the rears.
Hope the install goes smoothly! There's good writeups on this upgrade here on the forums, bleeding the front calipers is the trickiest part that is often overlooked.
-Icer
southxo
Feb 11, 2019 05:05 PM
dreamspeed
Jan 4, 2019 07:40 AM
aznpimpmaster
Brakes
Sep 29, 2015 06:50 PM
Alex Tappin
Sep 9, 2015 08:18 PM
teh215
Jan 5, 2006 01:06 PM
