So my obd2 won’t read
Old Apr 12, 2023 | 08:05 AM
Briancarey17's Avatar
Briancarey17
Default So my obd2 won’t read
I went to plug in my obd2 and the scanner jus loads forever and does nothing I tried the same scanner on another car and it worked so ik it’s not the scanner any ideas?
Old Apr 12, 2023 | 11:10 AM
icer5160's Avatar
icer5160
Does the Z have power? Good battery? Engine runs?
If all that checks out, then either you have a dead PCM or a wiring fault. What type of scanner is it? Brand/model?
Cheers!
-Icer
Old Apr 14, 2023 | 03:20 PM
Tomek350Z's Avatar
Tomek350Z
Take a look at the OBD2 connector and make sure the pins on 6 and 14 are not spread and are fully seated in the connector. If your scanner is powering up, chances are you have power at pin 16 and ground on pins 4 and 5, however its always good to check.
Are you trying to communicate with the key on in accessory, or with the engine running? Try both
fthis350z
Mar 24, 2023 07:30 PM
Nickzlow
Oct 9, 2020 06:00 PM
300zx32tt91
Sep 29, 2016 10:23 AM
350Zdj
Jun 29, 2013 03:04 PM
Xx AzN xX
Aug 30, 2012 05:22 PM
