JDM engine swap camshaft position sensor code
Old Apr 25, 2023 | 11:52 AM
omarbar2400's Avatar
omarbar2400
Default JDM engine swap camshaft position sensor code
Hello I have a manual 04 nissan 350z and blew the engine. I swapped in an imported vq35de jdm engine that came out of an auto 03-05 g35. the engine seems to run fine besides taking a very long time to start and throwing a cam position sensor code. I did notice the cam position sensors are slightly different from the US version so i did not swap over the old cam sensors. Is this a possible ecu problem do I need to get it flashed or was there anything I was supposed to swap over from old engine. any help is appreciated.
Old Apr 25, 2023 | 12:39 PM
icer5160's Avatar
icer5160
No, not a PCM issue. More than likely the cam sensors simply need to be replaced. This is a common maintenance item on VQ35s and only OEM sensors should be used. If you see aftermarket sensors in the replacement engine, then likely that's the issue. I would swap the sensors from your old engine into the new one just to see if the issue goes away. Odds are if the old engine didn't throw cam codes, then they are still good. The cam sensor P/N should be the same for all positions.
-Icer
Old Apr 26, 2023 | 07:04 AM
bre240z's Avatar
bre240z
As Icer said just swap over the sensors. That way you can rule out sensors being the problem. Omarbar where in CA are you located and if you dont mind me asking where did you purchase the motor from?
Old Apr 26, 2023 | 07:06 AM
omarbar2400
Im in Long Beach picked up the motor from jdmofcalifornia from ontario
Old Apr 26, 2023 | 10:11 AM
bre240z's Avatar
bre240z
how long did it take you to swap it out?
Old Apr 27, 2023 | 11:51 AM
omarbar2400
not too long I would say maybe 3-4 hours to get old engine out
CCCLZ-Silver
Dec 5, 2022 05:28 AM
Samuel Farrow
Mar 29, 2022 07:29 AM
lord_kinboat
Jan 22, 2019 07:00 AM
Nabice
Aug 19, 2016 08:13 AM
