Help like big help
Old Dec 23, 2023 | 11:58 AM
eight.oh.eight's Avatar
eight.oh.eight
Default Help like big help
Okay so my 350z dashboard lights stay on even after I turn off the car I’m not to sure what’s the problem but I’ve Alr did a code check and everything so if anyone has the same problem snd fixed it please help me
Old Dec 24, 2023 | 04:03 AM
Aeneas137's Avatar
Aeneas137
I assume you mean after the key is removed from the ignition? does any other light in the interior stay on as well?
a short-term fix to help while you sort this out is to install a battery negative lead quick release so that you don't have to use a 10mm every single time you park the car. I have one in two cars because they're so handy. got them at AutoZone. you have to cut the original negative lead terminal off of the wire and install the wire into the new negative terminal but it's worth it.
Old Dec 25, 2023 | 05:22 PM
dkmura's Avatar
dkmura
General & DIY Moderator
Welcome- it would help to post a few more details about your Z to establish a few things. What year and how many miles are on it? When did you buy it? Was this a problem when you first bought it? Were there any repairs or mods done to the Z that preceded the dash lights staying on?
This isn't a common problem with the Z33, so finding someone with the same problem may be difficult.
kacperkopka22
Apr 19, 2021 05:18 PM
Gators2001
South East
Oct 27, 2006 07:59 PM
