Help desperatly.
on
Hello everyone, i need help. i have a 2003 Nissan 350z base m/t, i had to take out my dash harness and my engine room harness and installed a new engine room harness, everything is plugged up on it, but the engine bay harness is not, i have one plug that is behind the key fob on the wheel and i can’t figure out where it goes at all, there are no other plugs for it. there is also a white plug that goes in front of the shifter, no clue where it goes. im assuming this plug is causing my main issue. my headlights do not come on nor do the tailights, but the brake lights work and also the flashers work as well. other then that i do not know what to do
Post pictures.
I can't imagine doing something that major to the car not taking photos as you went along. it depends on the options your car came with. If you don't have certain features, then there won't be any place to plug in things like cruise control
350Z/370Z Tech Moderator
![](https://my350z.com/forum/images/ranks/premier.gif)
![](https://my350z.com/forum/images/ranks/moderator.gif)
