My 350z keeps killing my battery’s
Old Apr 21, 2024 | 03:08 PM
cris235moran's Avatar
cris235moran
Default My 350z keeps killing my battery’s
My alternator went bad and the battery
I replaced both but for some reason my battery’s keeps getting bad I replaced 4 in 3 days I got all of them and they test bad and they we’re all new
all the batteries get bad after like 50 miles
Old Apr 24, 2024 | 12:18 PM
icer5160's Avatar
icer5160
You most likely have a short somewhere or a severe parasitic drain. But to completely kill a battery so fast, I'm guessing you have a major short or possibly a very bad connection somewhere (loose wire, corrosion, etc.). Look for signs of melted or hot electrical wiring. An infrared camera really helps with this. If this is something beyond your skills or tool kit, take it to a professional for proper diagnosis and repair. Electrical gremlins are usually not easy to sort out without experience and access to proper tools.
-Icer
Old May 2, 2024 | 03:53 PM
bre240z's Avatar
bre240z
I agree with icer. Maybe better to take it to an electrician to get this sorted out.
Old May 2, 2024 | 06:19 PM
MicVelo's Avatar
350Z/370Z Tech Moderator
One other suggestion: check the ground connection to the chassis (right below the top of the fender) or more importantly, check the cable-to-terminal itself. These cables rot out all the time but is overlooked because no one ever disconnects that end. A bad ground easily could be the culprit with symptoms of a bad battery or causing one because the alternator gets confused when it can't complete a circuit (or only marginally/intermittently does so).
Barring that, your electrical system is due for at least a charging system test. Alternator could be severely overcharging the battery (bad regulator) causing premature failure.
TJohns
Apr 19, 2023 05:20 PM
ItsjustaBrknZ:(
Jul 22, 2019 05:38 AM
aum16p1990
Apr 18, 2015 07:38 PM
superchargedg
Mid-Atlantic
33
Jun 28, 2009 03:17 PM
infidsg35
Mar 26, 2004 02:25 PM
