350z rear cv axel length
Old Jul 22, 2024 | 02:22 PM
Greasy Gabe's Avatar
Greasy Gabe
Default 350z rear cv axel length
Hey guys, I got a wide body 350z, I’m currently running 3inch wide spacers, and I’m trying to get rid of them, I also track the car so getting wheels with the right offset still will wear out my wheel bearings, so I’m looking to extend my control arms out more to either run smaller spacers, or hopefully none at all, I’ve found plenty of extended control arms for the front (because drift cars) and I’ve also found adjustable ones in the rear, only issue is my cv axels, if I’m going to push my rear knuckle out more, I’ll need to extended my cv axles. So I’m looking for the length of my current oem axels so I can find ones that are 3 inches longer that I can either modify to fit, or more preferable already fit. Thanks
Old Jul 23, 2024 | 09:09 AM
iideadeyeii's Avatar
iideadeyeii
Soooo, you are worried about wheel bearings?
Your "fix" to this worry is to make a custom suspension set-up and custom axles to compensate for it?
Old Jul 23, 2024 | 10:23 AM
GreyZ's Avatar
GreyZ
You will not find anything on the same chassis with a 6" wider track width. You will need custom axles that will not be cheap. I will be easier and cheaper to upgrade to the 370z wheel bearings and just replace wheel bearings often.
Orestis
Oct 15, 2023 07:41 AM
davids
Sep 13, 2010 06:13 PM
STRETCH
Aug 19, 2008 04:32 PM
