Overheating
Old Oct 22, 2024 | 03:11 PM
Jacksond99's Avatar
Jacksond99
Default Overheating
I have a 2003 Nissan 350z and it won’t stop overheating. I’ve replaced the thbermostat with an autozone one and it still overheated and I found in the forums that those ones tend to not work because they have 2 dissimilar metals or something so I ran it without the thermostat for about 3 months and it worked fine but i wanted to be able to warm the car up and have heat in the winter time so i decided to try and replace it with a OEM thermostat about 3 days ago and made sure it was bled and was running fine until today….. it overheated again and was bubbling over the overflow reservoir. I have also done a pressure test and a head gasket leak test and it passed both of them. The only other things I can think of is the radiator and the water pump but the water pump doesn’t show any signs of failure and I have no idea how to tell if a radiator is bad or not. Please help!
Old Oct 23, 2024 | 06:03 PM
icer5160's Avatar
icer5160
Do you have a 6MT or Automatic?
Make sure the electric fan package is working. If you turn on the AC (Max cold), both fans should kick on, if they aren't turning on, something is wrong with the fans.
Make sure your engine coolant temp sensor is working properly, would need a scanner that can show live data for this.
Under what driving conditions is it overheating? Lot's of stop and go traffic or while cruising at freeway speeds or doesn't matter?
Do you have any obvious signs of a coolant leak? Is the radiator original? What color is the coolant? Also, does the overflow reservoir have a dirty brown film lining the inside walls?
Did you follow the FSM coolant fill and bleed procedure when you replaced the thermostat? (Did you crack the bleed port on heater hoses near battery firewall?)
-Icer
Old Oct 31, 2024 | 02:31 AM
bisha's Avatar
bisha
Even if the water pump appears to be working, it could be faulty internally (e.g. a broken blade). Check if it is generating enough circulation by opening the radiator cap with the engine running and checking if the coolant is circulating properly.
Old Nov 13, 2024 | 02:14 AM
IsaacReed's Avatar
IsaacReed
It seems you copied it from somewhere else.
Spoiler
Old Nov 13, 2024 | 10:31 AM
iideadeyeii's Avatar
iideadeyeii
A fix would be to not run the car more than a few minutes at a time. You're welcome 1 post user who never logged back in
Old Nov 21, 2024 | 05:46 AM
bmccann101's Avatar
bmccann101
You have a large air bubble in the system, almost 100% sure.. use a vacuum fill device and this will never occur again.
Old Nov 21, 2024 | 03:45 PM
icer5160's Avatar
icer5160
I love the vacuum fill tool! There are some vehicle specific caveats when using it, but I've had good success with it once I figured out how to properly prime it. Sadly, the user who started this thread has ghosted.
Cheers!
-Icer
Sw1fty
Jan 6, 2024 11:19 PM
BlastyBlasty99
Nov 4, 2021 11:36 PM
Imports only
Aug 6, 2019 12:12 AM
iiLLuSiiV
Nov 21, 2018 07:14 AM
zprz
Dec 2, 2015 12:56 PM
