I need help with my 2005 nissan 350z
Old Mar 20, 2025 | 04:37 PM
Serna's Avatar
Serna
Default I need help with my 2005 nissan 350z
Hello, I've been having problems with my 350z basically I can't accelerate well when I turn on my car everything is perfect but when I put it on Drive and touch the accelerator it loses power and I have to brake and accelerate little by little but the speed is limited I already changed the pedal sensor, the gasoline pump, the body throttle, and the two camshaft sensors and I still have the problem if you have had it or know how to solve it it would be very good for me.
I have the TCS and Slip light. Or if you now a good mechanic that knows about 350z in Miami also appreciate
Old Mar 20, 2025 | 04:45 PM
MicVelo's Avatar
350Z/370Z Tech Moderator
Well, obviously not so perfect.
First things first.... did you pull codes to determine the sensors (and all the likely unnecessary parts) were bad? If so, what were the codes? And, what sensors did you put in? OE (Hitachi) or a general store brand? (O'Really, Autozoo, that sort of thing?)
What trim is your car? Meaning, do you have VDC, TCS or a base model? Have you changed your wheel/tire setup recently?
IOW, need more details.
Old Mar 20, 2025 | 04:54 PM
Serna's Avatar
Serna
[QUOTE=MicVelo;11137660]Well, obviously not so perfect.
Hey thank you for taking the time to read, yes I read the codes and it's the
P0345
Camshaft Position Sensor A Circuit Bank 2
And
P2135
Throttle / Pedal Position Sensor / Switch A/B Voltage Correlation
I changed the Body Throttle because it was a generic one and I put one itachi brand, the pedal sensor I put one oem and the camshaft also itachi and all the changes I made was to see if it was solved but I think I spent money for nothing 😭 It's a 2005 350z base model
Bamdon16000
Jul 8, 2022 01:57 PM
kacperkopka22
Feb 14, 2021 07:03 PM
Julita128
Jun 16, 2018 06:05 PM
Rigs19
Jun 10, 2014 07:31 PM
black5z
Mar 7, 2005 08:52 PM
