2004 350z
Old Sep 23, 2025 | 03:09 PM
Scott2112's Avatar
Scott2112
Default 2004 350z
All lights work,no tail lights????.I have replaced bulbs checked fuses,wires.i don't have a clue .anyone have ideas?
Old Sep 24, 2025 | 05:19 AM
Heel Til I Die's Avatar
Heel Til I Die
Are you saying that none of the lights in the tail lights illuminate at all? No brake lights, running lights, etc?
Old Oct 3, 2025 | 01:42 PM
bisha's Avatar
bisha
A poor ground connection (loose, corroded, or broken ground wire) will prevent the lights from turning on even if power is supplied. Especially on 20-year-old cars like a 350Z
Old Oct 3, 2025 | 05:06 PM
icer5160's Avatar
icer5160
There's a main body ground mounted to the rear of the trunk behind the back panel that covers up the trunk latch. (Assuming LHD vehicle) The ground connection is on the passenger side behind this panel. If the vehicle has been messed with in the past, a lot of people tap into the reverse wire to power backup cameras. This harness runs across the trunk floor pan on the driver's side and might warrant a look if a wiring fault is suspected.
Cheers!
-Icer
Old Oct 3, 2025 | 08:03 PM
Scott2112's Avatar
Scott2112
Default Ty
Hey guys and gals,try for reply all lights work ,but the tail lights.night lights.sort of makes no sense that turn signs hazards brakes work.but no tail lights.guess ground somewhere.have no power to them.meter chk.appreciate the replies.
