Problem with my Z again.HELP!
I took my car to dealer so many times.
and they still saying my car is NORMAL!
can anyone help me on this problem?
what should I do? what do I tell dealer to fix or take a look at?
my problem is...
-hear rattling on low RPM 1000~2000.
(sounds like old azz car bout' to break down.)
-i hear the same rattle when I push the clutch in to shift
from 1st to 2nd gear. (the whole thing shakes)
-little bit of rattle when I go on the sharp bumps.
-and it ONLY happens when the car is warmed up.
or maybe its not loud as much as later.
And i drove other Z's at Meets and stuff, and my car was the only one that makes the noise.
I took it to 2 different dealers and took it in couple times.
they all told me that my car is normal.
first when they drive it, they say..
"its not normal, wont you leave your car here.."
and later they call me back and saying that my car is normal.
what should I do?? help please...
my problem is...
perhaps, check under the car... I get rattling that is sorta like yours(not so much on the clutch), and its from the exhaust rattling against the crossmember underneith.
I have aftermarket though, so I know why mine is touching. might be worth investigating anyway if no one has a better idea.
