tire feathering
Old Mar 18, 2004 | 03:42 PM
touring's Avatar
touring
Default tire feathering
Went to my dealer today for the second time with the symptoms of tire feathering. The first time they rotated (back in Nov) and aligned the wheels, since the symptoms returned I wanted to know what the next step to end this problem would be. The dealer told me they had not received any new information about this problem and my best bet would be to call Nissan. Since the car just turned 7,000 miles the tires are not worn as yet, but I want to head off a problem to come. Any advice. Thanks
Old Mar 19, 2004 | 06:51 AM
Big Sexz's Avatar
Big Sexz
My dealer told me the same thing. So much for fixing the problem on all 04's. Mine was built 07/03 so I guess they didnt realize it yet. I took mine in at 8300 miles and they said "If this doesnt work, you will have to call NNA to get them involved. Maybe they will give you new front tires." Hopefully the alignment works.
Old Mar 19, 2004 | 07:49 AM
mcjohn1's Avatar
mcjohn1
NEW FRONT TIRES- call NNA now, my dealer did it without the call to NNA but then I showed him posts from this and other sites when I first took it to him!
Old Mar 19, 2004 | 08:13 AM
FairladyZ's Avatar
FairladyZ
They should replace your tires no questions.
Old Mar 19, 2004 | 08:25 AM
MRfire's Avatar
MRfire
Yep - new tires....mine are on order now
Old Mar 19, 2004 | 08:28 AM
touring's Avatar
touring
I called Nisssan today they will call the dealer and give instructions for repair and get back to me in 24 hrs. Will replacing the tires solve my problem?
Old Mar 19, 2004 | 08:52 AM
FairladyZ's Avatar
FairladyZ
Man, I hope so. The toe-in didnt correct the feathering as I now can see it on the "good side."
Old Mar 19, 2004 | 08:59 AM
touring's Avatar
touring
Are we to expect the same brand of tire and if so how does this solve the problem if whatever the problem was the first tires were worn?
Old Mar 19, 2004 | 10:36 AM
FairladyZ's Avatar
FairladyZ
The president of the Z club of texas had it done and he said it took care of the problem. After they replaced the tires. Once he made sure the feathering was solved he ordered the Nismo wheels and he has been happy ever since.
Old Mar 19, 2004 | 11:28 AM
touring's Avatar
touring
Thanks all, on a similar subject, is it true that Nismo wheels will void your warranty because they are non vdc. I thought I read this somewhere. If this is true how are other wheels affected by other manufactuers?
Old Mar 19, 2004 | 12:29 PM
zunzet's Avatar
zunzet
I'm dropping my car off next week for the second time to fix the problem. I will insist on new tires.
We'll see how that goes...
They better, since they destroyed my rims the last time. All they did was rotate the 2 front tires, balance and re-align.
Keep your fingers crossed.
Old Mar 19, 2004 | 12:39 PM
tdukeman's Avatar
tdukeman
this issue was supposedly fixed with the release of the 2004.5 release where they replaced the suspension. I just got mine last week so I was lucky enough to have a 4.5 not sure though if the rumors are true if it's fixed or not, only time will tell. I didn't get the right manual either so I have to wait for the dealership to get a 2004.5 one in, or I have to go the Nissan's site and spend $200+ for it.
Old Mar 19, 2004 | 12:45 PM
pisces9ca's Avatar
pisces9ca
I mentioned the feathering issue to the Service Manger at the dealership where I purchased the car and got this form letter reply:
"In regards to the tire feathering issue, 1st you will have to have the vehicle inspected buy a Nissan technician to verify that the feathering is causing road noise. The tire feathering TSB issue is based on it making a growling type noise while stopping. If that is found by the technician then Nissan will address
it. "
I was hoping to avoid wearing out the tires prematurely by rotating them before they were worn badly but it seems they have to 'roar' before they will do anything about it.
Old Mar 19, 2004 | 12:47 PM
fblue's Avatar
fblue
tdukeman,
From what a Nissan Rep told me, all 2004's have the new suspension. I also read that same thing from someone on this site who said he spoke with a 350Z expert rep named Bianca who said the same thing. Either way, I'm still waiting to see how my tires wear. I'm hoping for the best.
ablaine
Nov 29, 2016 10:13 AM
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
