Changing side skirt - Help
Old Mar 28, 2004 | 10:38 AM
jj1814's Avatar
jj1814
Default Changing side skirt - Help
I'm changing my driver's side side skirt and need some help.
What do I use to remove the two "clips" that are holding the rear part of the skirt onto the body (inside the front of the rear wheel well).
Ive got all the bolts off on the underside of the skirt already.
Thanks
Old Mar 28, 2004 | 11:29 AM
flynnibus's Avatar
flynnibus
Z Flier
Make the center pin pop up.. use a flat head screw driver (they don't come out.. just lift up).. then pull the entire clip out of the hole
Old Mar 28, 2004 | 12:49 PM
jj1814's Avatar
jj1814
ahhh ok. i'll try that. I'm afraid to just go yanking on stuff.
are there any clips underneath the door sill that I need to know about?
Old Mar 28, 2004 | 01:54 PM
jj1814's Avatar
jj1814
thanks for the help flynn...
I looked at the replacement side skirt and saw that i DID need to do a little tugging to get the stock one off.
I know my new neighbors think I'm really weird now. I've been outside laying on the ground getting dirty all day working on my car. I got a few weird stares from some of the neighborhood kids and a couple of other females. But I feel accomplished
Old Mar 28, 2004 | 02:32 PM
teh215's Avatar
teh215
That is why I say do as much of the work on your car as you can that you feel comfortable with. There is not better feeling than doing it yourself and taking pride in your work. Pics?
Old Oct 26, 2004 | 10:08 AM
onii's Avatar
onii
can u elaborate on removal procedure? im about to replace my skirts also. =]
Justin100
Nov 25, 2021 06:26 AM
kyin
Oct 15, 2015 05:54 AM
