small dimple on door panel casued by seatbelt buckle
Old Apr 6, 2004 | 06:48 AM
milanista's Avatar
milanista
Default small dimple on door panel casued by seatbelt buckle
Hello all,
yesterday I noticed a small dimple on the driver side door panel. The dimple was caused by the seatbelt buckle getting pinched between the seat back and the door panel itself when I closed the door the day before. After noticing that and adjusting the buckle, I expected the dimple to go away within a couple of hours or so, but this morning it's still noticeable. Has any of you experienced this problem, and will the indentation on the door panel go away after a while, maybe through a couple of "heat cycles", or should I expect it to be there permanently? Is there a "trick" to get the dimple out?
Thank you in advance for your input.
Old Apr 6, 2004 | 08:52 AM
ragtopz's Avatar
ragtopz
as far as i know, it is permanent. i havent checked mine recently, but i know at the least, it lasts a long time.
Old Apr 6, 2004 | 10:21 AM
milanista's Avatar
milanista
it sounds as though you did the same thing as I did then, with the seatbelt buckle...
3vilbunny
Jul 18, 2017 05:10 PM
nanotech
Oct 2, 2015 05:02 AM
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
