Forced Induction or Naturally Aspirated?
Old Sep 30, 2002 | 07:59 PM
donnyz's Avatar
donnyz
Default Forced Induction or Naturally Aspirated?
What are you gonna do???
Old Sep 30, 2002 | 08:03 PM
Boomer's Avatar
Boomer
Default Re: Forced Induction or Naturally Aspirated?
NA all the way.
Boomer
Old Sep 30, 2002 | 08:06 PM
Brad4rdHay's Avatar
Brad4rdHay
probably get the most out of the NA engine as possible. Gonna be hard.
Old Oct 1, 2002 | 07:45 AM
Michael-Dallas's Avatar
Michael-Dallas
All motor or supercharger.
Michael.
Old Oct 1, 2002 | 08:09 AM
XeroDgrees's Avatar
XeroDgrees
N/A all the way!!!
I've got big plans for the engine!
Old Oct 1, 2002 | 08:11 AM
350zSpeedRacer's Avatar
350zSpeedRacer
Do what you can to the motor first, then if it's still not fast enough (which it never is) supercharge it.
Old Oct 1, 2002 | 08:15 AM
XeroDgrees's Avatar
XeroDgrees
Yea but if you go with higher compression pistons you can't just supercharge it... you'll have to lower the compression to enable higher safer boost.
Old Oct 1, 2002 | 09:29 AM
mydogscool's Avatar
mydogscool
No lag for me - NA baby
Old Oct 1, 2002 | 09:39 AM
digerydingo's Avatar
digerydingo
Wow, with the 300ZXTT I would have expected more people to lean towards tubos. I would go for NA or Supercharger as well. Factory built turbo engines rock for pushing tons of power at little cost/work but switching an NA to turbo has it's own share of ups and downs. Don't get me wrong, I know they work and seen many done on all types of cars but it usualy takes twice the work and 10x the money. Plus I don't plan to push much more than a well tuned NA engine can put out.
Old Oct 1, 2002 | 09:55 AM
Michael-Dallas
IMO, more care and attention is required when turbos are involved. Superchargers seem more consistent with power output and reliability; not as much constant tuning is required for a reliable setup.
Also consider the VQ block is aluminum so I wouldn't expect it to last very long w/ turbos and high boost. Power-wise, my 300 will blow the doors off my 350 so bad, it's not even funny. But, I didn't buy a 350 for its power and the increase that a supercharger, cams, and/or ecu would provide suffices for me.
Michael.
Old Oct 1, 2002 | 10:22 AM
RobJames's Avatar
RobJames
What is the difference between a turbo and a supercharger? Are they not both forced induction?
Old Oct 1, 2002 | 10:38 AM
padam07's Avatar
padam07
They are both forced induction. If you don't know thedifference then do a search and you will find everything you need. I don't feel like explaining, my hands have done enough typing today.
Old Oct 1, 2002 | 10:43 AM
flyzmd80's Avatar
flyzmd80
Turbocharger uses engine exhaust to drive a turbine which drives the compressor, hence the lag in power. A supercharger is geared to the engine or uses a belt to drive the compressor and delivers power sooner.
BZ
Old Oct 1, 2002 | 11:22 AM
Bosshog's Avatar
Bosshog
Give me FI .
Old Oct 1, 2002 | 12:51 PM
Chebosto's Avatar
Chebosto
once you've had boost, you cant go back..
Old Oct 1, 2002 | 12:56 PM
InternetABYSS's Avatar
InternetABYSS
FI as long as its not crpa and dont cost a ton
Old Oct 1, 2002 | 01:01 PM
acid burn's Avatar
acid burn
Keep the car as stock as possible and NA. As I like to say: buy the performance want with the car, don't try to add it afterward.
I would like to get a project car though, to wrench on it to my heart's desire, without worrying about practicality. 1000hp and a power band from 7,000 to 8,000? I'll take it!
sales@czp
Sep 23, 2019 03:30 PM
