Rolling the windows
I know you can use your keyfob to roll the windows down but can you roll them back up using the same method? I tried it a couple of times and it don't do anything
Originally posted by 1stogie
How do you roll your windows down with your remote???
--Josh
3-6 Pre-driving checks and adjustments Page 87
Opening the windows
Push the UNLOCK button on the keyfob.
The driver's door will unlock.
Continue to press the UNLOCK button for 3
seconds. All the door windows will be lowered.
Continue to press the UNLOCK button until
windows are fully open.
To stop lowering the windows, release the UNLOCK
button.
To start lowering the windows, press the UNLOCK button again for 3 more seconds.
button.
2003 Nissan 350Z Owner Manual
Pre-driving checks and adjustments 3-3 Page 84
Opening and closing windows
Turn the driver's door key to the UNLOCK
position and hold for about 1 second, all door
windows will begin to lower.
To stop opening, turn the key to the neutral
position.
To close all door windows, turn the key to the
lock position and hold for about 1 second.
To stop closing, turn the key to the neutral
position.
In the event of a hand in the way, or other
obstruction, the auto reverse function will activate.
position.
position.
for rolling them up, there is a thread by someone who is going to sell an add on that adds more uses to the window roll up and what not. I dont have the link to the thread but here is the site www.kptechnologies.net
Originally posted by FairladyZ
Why pay for it if you can use the key? I knew one could open the windows with the remote, but not close them with the key. thanks xtazee.
i like the idea of being able to roll the windows up from the key fob because that means i dont have to be right next to the car. if i was going to be standing next to the car with the key in the slot i figure i might as well put the key in the ignition and roll the windows up from the inside. but from the keyfob you get versatility!
