Tire Pressure (monitors)
I have a stupid question for everyone. My tire pressure monitor on my Touring/Performance model reads that there is 34 psi in the front and 37psi in the rear tires. What is the pressure supposed to be, and where is the best place to get the correct tire pressure? I've heard that you should get it from the sticker on the inside of the door, but some people have told me that I should get it from the side of the tire. Help........
The door has the recommended pressures from Nissan, the tire has the manufacturers maximum recommended pressure. You should go with the door jamb pressures. If you race on a track, there are other considerations, but for street use, just go with the factory recommendations.
Yes, my tires have 34psi for both front tires and 37 psi for both rear tires. What psi are you putting in your tires? I don't do any track driving just street driving.
Thanks.
Thanks.
