Center Console Compartment Door
I've noticed that on some models, that door opens and goes inside the dash, but on my Base it only flips out and stays out. I know all the Navigations have this special door but I've seen others without Nav. that have the same type of door.
I actually replaced my entire '04 compartment/door with the equivalent '03 parts. It appears that Nissan has upgraded the new '03 compartment parts to be a bit smoother and more robust than the original parts that came in the '03 cars. The new doors aren't as jiggly and cheap feeling as the original '03 doors I messed with when the '03 cars first came out.
FYI: I wanted the '03 compartment since I did an aftermarket nav install, and the '03 compartment opening is significantly bigger than the '04 opening. Makes it much easier to fit the nav screens in there.
