How to tap into SPEED SENSOR / reading
Old Oct 14, 2002 | 09:24 PM
Subw00er's Avatar
Subw00er
Default How to tap into SPEED SENSOR / reading
Anyone know how/where to tap into this wire?
Old Oct 14, 2002 | 11:27 PM
SKiDaZZLe's Avatar
SKiDaZZLe
Charter Member #34
you are probably passed this, but there is a wire going into the ECU that carries this information in a pulse format. i will let you know which it is, when I get the ECU diagram tomorrow.
m
Old Oct 15, 2002 | 04:26 AM
Subw00er's Avatar
Subw00er
Wow I'd love for you to tell me this..
I'll tell you what I know so far:
Old Oct 15, 2002 | 04:30 AM
Subw00er's Avatar
Subw00er
pic:
Attached Thumbnails How to tap into SPEED SENSOR / reading-notes-copy.jpg
Old Oct 15, 2002 | 09:04 AM
Subw00er's Avatar
Subw00er
Ok, I found it!!!!!!!
Looks like we have to tap into the "unified meter and a/c amp"
This is a white wire and its the speed sensor reading. Its a 8-pulse on the Z.
Old Oct 15, 2002 | 09:06 AM
Subw00er's Avatar
Subw00er
SKiDaZZLe, fyi, you can not tap into a pulse wire at the ecu because one does not exist. The z uses a central information transmission system where the data is encrypted and sent to various areas on the car. If you look at the wiring diagram for the ECU you will NOT see a Speed terminal.
Old Oct 15, 2002 | 05:26 PM
SKiDaZZLe's Avatar
SKiDaZZLe
Charter Member #34
or you can tap into #20 on the combination meter (gauge cluster). this is the other side of that connector
i have the service manual too
you are right, the unified meter and a/c amp is easier to get to, as it is the white box behind the A/C controls... if you are installing something near the center console.
michael
ps, the wire (#26) is white
Old Oct 15, 2002 | 05:42 PM
nizl's Avatar
nizl
Originally posted by Subw00er
The z uses a central information transmission system where the data is <font color=red>encrypted</font> and sent to various areas on the car.
Do you mean "encoded"?
If not, please explain more...
Old Oct 15, 2002 | 06:04 PM
Subw00er's Avatar
Subw00er
nizl, I supposed encoded is a better word. .
VQracer, true! I didnt know how to get to the gauge cluster.. It looked complicated.
This is for a Apexi RSM w/accellerometer install.
Old Oct 15, 2002 | 06:33 PM
Subw00er's Avatar
Subw00er
Ya that one.. its looks cool, except its in lame *** km/hr. Why cant the rest of the world just comply? {sarcasm}
Old Oct 15, 2002 | 06:40 PM
r4square's Avatar
r4square
don't you mean, why doesn't USA comply with the rest of the world?
Brain works better working in tens rather than 4,8,12......
Old Oct 15, 2002 | 06:41 PM
sschmuve's Avatar
sschmuve
Kph is the majority. Metric makes more sense anyways.
Old Feb 3, 2004 | 04:51 PM
mikeef's Avatar
mikeef
In Europe, the SPG is on wire 34 of the unified meter and ac amp.
Old Feb 4, 2004 | 05:47 AM
cedusett's Avatar
cedusett
I'm sorry if this is a noob question, but why would you want to do this?
Old Feb 4, 2004 | 11:30 PM
mikeef's Avatar
mikeef
In order to connect up to a satnav system.
Old Feb 9, 2004 | 07:33 AM
the7ferret's Avatar
the7ferret
wouldn't a decent sat nav system have GPS and from that figure out the true Speed?
Old Feb 9, 2004 | 12:19 PM
meeno's Avatar
meeno
yes but when you go in a tunnel and lose signal the wheels help tell the NAV where you are
Old Feb 24, 2004 | 09:56 AM
mikeef's Avatar
mikeef
For some reason, the pioneer system is also more likely to put you incorrectly on a road (if yo9u are off road) without the speed pulse generator wired in.
MAsSIVrOOM
Oct 20, 2023 10:50 AM
2ndchanceZ
Oct 26, 2015 08:03 PM
