30K miles maintenance
Old Aug 4, 2004 | 06:04 AM
Vlad's Avatar
Vlad
Default 30K miles maintenance
My dealer told me that I need a coolant flash ($80) and transmission fluid flush ($120?) because of 30K miles.
I remember something about transmission sealed for life... or was it gearbox?
Anyway anybody know a link to a DIY for 30K maintenance? I'm quite sure if my dealer quoted me $200, I can do it for $50. Any chanse to screw something bad?
Thanks
Old Aug 4, 2004 | 08:44 AM
Vlad's Avatar
Vlad
bump!
Old Aug 4, 2004 | 09:51 AM
PoWeRtRiP's Avatar
PoWeRtRiP
Default Re: 30K miles maintenance
Thanks
coolant flush is diy, tranny fluid should be able to get done at another place for 60-70 at the most.
also id recommend changing your diff fluid since you autocross that would b like 50-60. how bout fuel filter, pcv valve, etc are those part of 30k? im coming up on mine so plz share.
Old Aug 4, 2004 | 11:57 AM
Vlad's Avatar
Vlad
Dealer only mentioned what I said. I wish I can find out more... Gotta check the manual and service book should be there somewhere.
Old Aug 4, 2004 | 01:41 PM
Apexi350z's Avatar
Apexi350z
Charter Member #50
yeah, my dealer recommended Coolant Flush, but he didn't say anything about transmission flush.. I heard it's not a good idea to do transmission flush.. Maybe just change out the transmission oil...
Old Aug 5, 2004 | 05:10 AM
Vlad's Avatar
Vlad
What coolant do I use and how much do we need?
Old Aug 5, 2004 | 04:29 PM
tivaj's Avatar
tivaj
since you have 30000 miles on your Z, may I ask you if there has been issues with you car? what are they and when did you start experiencing them?
Regds
Old Aug 6, 2004 | 05:30 AM
Vlad's Avatar
Vlad
no issues at all. except standard stuff from existing NTBs: amplifier, left window grease, hatch not opening. All fixed in one day. Well, hatch still won't go up by itself.
Old Aug 6, 2004 | 11:46 AM
MonkeyBoy's Avatar
MonkeyBoy
Your 30k maintenance according to the service manual only calls for an oil change and an air filter replacement. Everything else is inspect and replace if needed. Since somebody mentioned that you autocross, I would definitely change the tranny and diff fluids. Hell, I did that at my 30k maintenance and I hardly ever track the car. As for the fuel filter, it will never be replaced seeing as how it is part of the gas tank and "maintenance free." Not sure about the PCV valve. The coolant on my car is in very good shape (my older brother is an auto tech at a local dealership).
Things you should do ...
- Oil Change
- Tranny Fluid Change
- Differential Fluid Change
- Air filter replacement
- Inspect drive belts, replace if needed
- Inspect fuel lines, replace if needed
- Inspect brake lines/cables, replace if needed
- Inspect brake pads/rotors, replace if needed
- Lube suspension parts (WD40 works well here)
Things you might want to do, but probably do not need to ...
- Coolant flush (manual says to replace at 60k, then every 30k)
- Anything not listed above.
The inspection items above are just that, check em out and see if they are worn down or need replacing. The majority of these items will be fine however.
Hope this helps.
Old Aug 6, 2004 | 11:48 AM
MonkeyBoy's Avatar
MonkeyBoy
A transmission flush is changing the tranny oil, but at a pressurized setting in order to get all of the old fluid and metal shavings out of the case.
Old Aug 6, 2004 | 01:10 PM
BOZ23's Avatar
BOZ23
good info!
Old Aug 9, 2004 | 05:11 AM
Vlad's Avatar
Vlad
Thanks!
lapham3
Oct 7, 2022 03:15 PM
Fixxxercask
Nov 9, 2015 11:10 AM
kyin
Oct 15, 2015 05:54 AM
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
