VQ37HVR Mods and Support related to the 2009+ VHR engine
370z Dyno'ed w/ Chart!
Old Dec 18, 2008 | 08:07 PM
Bibimbap's Avatar
Bibimbap
Default 370z Dyno'ed w/ Chart! 12.18.08
Many thanks goes to 370zfanatic and the370z.net
Old Dec 18, 2008 | 08:42 PM
aznmojo's Avatar
aznmojo
wow thats pretty good... assuming that means it puts out 280 to the wheels?
Old Dec 18, 2008 | 08:56 PM
Motormouth's Avatar
Motormouth
ps is a higher rating than HP iirc.. not much though.
and the first pic looks like a chop
Old Dec 18, 2008 | 09:46 PM
BrianV's Avatar
BrianV
That's a dynapack too so it's not comparable to other dyno's including the more popular dynojet.
Dynapacks always put out higher numbers...
Old Dec 18, 2008 | 10:42 PM
TomatoEvo's Avatar
TomatoEvo
Is it just me or do the HR's dyno similar HP numbers on Dynapack? I remember seeing two at 280 to 290 HP stock. I hope I'm mistaken.
EDIT: Found the thread I was thinking about. http://g35driver.com/forums/g35-seda...o-results.html
Old Dec 19, 2008 | 05:10 AM
tranceformer95's Avatar
tranceformer95
Did anyone notice it has the non-sport wheels? Not 100% sure about the models, but wouldn't that mean it's the 7AT and not the 6MT?? That would definitely affect the dyno reading.
Old Dec 19, 2008 | 05:35 AM
DIGItonium's Avatar
DIGItonium
You can get 6MT with or without the optional sport package. There are two trims: BASE and TOURING. Both have 7AT and 6MT as options. Work pwnage... can't see dynos! Blue *****...
I personally don't care much about how much power it makes, but I would definitely compare the DE, REV-UP, HR, and VHR power bands.
Old Dec 19, 2008 | 05:36 AM
xNeo's Avatar
xNeo
Why does it have volks in the first pic but not the second?
Old Dec 19, 2008 | 05:51 AM
Vengence's Avatar
Vengence
Stop bringing reality into this!
Old Dec 19, 2008 | 05:53 AM
savvy's Avatar
savvy
Too many unknown details, I'll wait for more reliable dyno's to come out.
Old Dec 19, 2008 | 05:54 AM
jnifong's Avatar
jnifong
this pull was done in 3rd? I guess they selected which ever gear gave them the best results. Results may vary in 4th and 5th (5th I'm assuming is 1:1)
Jon
_______________
'08 G37S Black/Black 6MT | Premium | Navi
Get your wrong on:
http://www.sheepholetees.com/main.php
Old Dec 19, 2008 | 06:16 AM
bryan@Z1's Avatar
bryan@Z1
Vendor - Former Vendor
5th is 1:1 on the 6 speed so that would be the correct gear to pull in. This seems a lil bit suspect all around.
Old Dec 19, 2008 | 06:24 AM
TomatoEvo's Avatar
TomatoEvo
I agree with Bryan about this being fishy. Dyno'ing in a lower gear will usually give you higher numbers.
Old Dec 19, 2008 | 06:35 AM
jnifong's Avatar
jnifong
As always, there are too many different ways to do dynos and they're mainly good for testing gains when you slap performance parts on, and that's only true if you come back to the same dyno everytime after each change. They way dynos are done are, to me, like conducting an experiment many different ways to get the results you want rather than the actual.
jon
_______________
Get your wrong on:
Old Dec 19, 2008 | 07:27 AM
ITR#203's Avatar
ITR#203
Yes, but this is a Dynapack, not a Dynojet. Dynapacks, while generally considered more accurate, read about 8%-10% higher than Dynopacks and about 15%-20% higher than Mustang dynos, partially because the drivetrain loss of actually turning the wheels and the losses caused from transferring that power from the tires to the roller are no longer there - I have heard of Dynapacks being calibrated to give Dynojet numbers however. Also, when I say accurate it is not to say that the number it gives is better but rather that the results are more consistently repeatable, giving a better view of how much power you've actually added via mods when you dyno again and when comparing to other cars dynoed at the same place. I believe is the more useful way to use a dyno plot in most cases anyway, given that the day's conditions and calibration of different dynos can result in wildly different numbers even for the same car, make comparing different dyno plots from across the country an inexact science at best.
As part of ensuring accuracy on Dynopacks, you can specify the gear ratio on the car. As a result, technically you could dyno in 2nd gear, the problem would not be so much inflated power numbers as much an erratic graph.
My issue is that if it is calibrated as a normal Dynapack, why is it only making 280? I'd definitely expect at least 300 hp on a Dynapack and hope that this particular one was simply calibrated as a Dynojet in which case 280 would not be too bad.
Old Dec 19, 2008 | 08:32 AM
jnifong's Avatar
jnifong
If I remember right, that's what the G37s are putting down. The Z is rated at 332, the G at 330, so 280's pretty close.
jon
_______________
Get your wrong on:
Old Dec 19, 2008 | 09:18 AM
ITR#203's Avatar
ITR#203
jon
_______________
Get your wrong on:
You must have completely missed my rant about Dynapack vs. Dynojets. Yes, if it was a Dynojet, it should be making around 280 hp - not a problem. But given that most dynopacks read 8% to 10% higher, this should be making around 300 at least.
Old Dec 19, 2008 | 10:09 AM
skaterbasist's Avatar
skaterbasist
Some of you act like if this motor is brand new. It's been on on the G37 for over a year. And it usually puts down 270-280 rwhp on your typical dynojet.
Old Dec 19, 2008 | 10:11 AM
skaterbasist
Usually Dynapacks do read a bit higher than dynojets. But Dynapacks can read lower than dynojets if they are calibrated that way.
I've dyno'd my car at two different shops with two different calibrations on their dynapacks on one of them read 280 rwhp whereas the other one read 255 rwhp. That's with the same exact mods. (The owner claimed their calibration was much more conservative).
Old Dec 19, 2008 | 12:38 PM
06Gcoupin's Avatar
06Gcoupin
Bahaha, these volks have the 350z brakes behind them...
Peep the front wheels....seems as if the volks have dissapeared.
