2009+ 370Z General discussion and news for the Z34 (2009+) Nissan 370z with the new 3.7-liter V6
Synchro Rev-Match: Video and More In-Depth Info 12.19.08
Old Dec 19, 2008 | 01:49 PM
Bibimbap's Avatar
Bibimbap
Default Synchro Rev-Match: Video and More In-Depth Info 12.19.08
Original Link:
http://jalopnik.com/5114318/nissan-3...o-super-driver
Heel and toeing is one of the hardest-to-master and most rewarding driving techniques, and now the Nissan 370Z’s manual transmission will do it for you.
Heel and toeing is the confusingly named term for using your right foot to hit both the brake and gas pedals while downshifting. The idea is to match the engine revs to what they’ll be in the lower gear before you release the clutch in that gear, all while braking to slow for a turn. If you get it right, the shift into the lower gear (or gears, it’s most rewarding doing this as you shift down through two or more gears) is incredibly smooth and allows you to brake later and harder as you turn into the corner. This means more speed, less chance of spinning and an easier time for your engine and transmission. Before racecars went all paddle shifty, you had to heel and toe or you’d blow up the engine.
Sound complicated? That’s because it is and that’s where the new-for-2009 Nissan 370Z comes in.
{Too much trouble to grab the source code ... Cant embed video; sorry}
Go to site for the video.
When you downshift, it uses the ABS sensors to read the speed of the tires, compares that data to the speed of the engine and the gear being selected, and then actuates the electronic throttle to bring the revs up to the appropriate level. It does all that faster than a human driver could, guaranteeing perfectly rev-matched downshifts every time. This means that, as long as you know how to drive a stick, you’ll look like and sound a heroic racecar driver every time you get behind the wheel.
By now, if you’re in the majority of casually enthusiastic drivers, you’re thinking this sounds pretty good. It’ll help you go faster, be safer while doing so and, most importantly, look good. The problem is that if you’re a hardcore driver, you’ve spent years developing the ability to heel and toe and don’t want to share it with the everyman, nor have it done for you. The system does have an off-switch, allowing keen drivers the ability to challenge themselves, but it does represent a further erosion of voluntary control and thus the skills necessary to go fast being removed from the driving experience.
[Source: Nissan]
Old Dec 19, 2008 | 02:38 PM
Mazinger Z's Avatar
Mazinger Z
Cool, but does the vid have sound for you? No sound for me.
Old Dec 19, 2008 | 02:41 PM
Atag012's Avatar
Atag012
old post
Old Dec 19, 2008 | 03:42 PM
Bibimbap's Avatar
Bibimbap
Originally Posted by Atag012
old post
This wasn't a perceived idea and informal description as to what the Synchro Rev-Match is; it's a release by NISSAN to explain how the Rev-Match works and how it should be used.
Old Dec 19, 2008 | 10:38 PM
Konvict's Avatar
Konvict
nice post..but yeah i want a video with sound...seems like awesome technology tho...gets kinda tiresome doing the heel and toe thing
350Z_Al
Oct 29, 2020 07:44 PM
Justin100
Nov 29, 2015 03:58 PM
Tochigi_236
Sep 27, 2015 03:40 PM
