2009+ Nissan GT-R Nissan R35 GT-R Discussion
AAM Competition GT-R Products Lineup
Old Mar 27, 2009 | 11:48 AM
Clint@Altered's Avatar
Clint@Altered
Arrow AAM Competition GT-R Products Lineup
Hey everyone,
I'll keep this updated as we roll out more products. We've got quite a few more in development!
If anyone has any questions, feel free to PM Me, Jeremy@Altered, Mike@Altered or Jon@Altered.
I can also be reached at ClintonM@AlteredAtmosphere.com
AAM Competition Exhaust Soundclips / Dyno Vids
http://www.alteredatmosphere.com/soundclips/
Pricing & additional info is available here on our GT-R Website
http://www.alteredatmosphere.com/mm5...egory_Code=GTR
AAM Competition 3"~3.5" Mid-Pipe
AAM Competition 3" Mid Pipe is the ultimate performance catalyst for the Nissan GT-R. Produced from highly durable 16-gauge T-304 stainless steel, AAM Competition 3" Mid Pipe replaces your factory midpipe to achieve improved engine power, response, and efficiency, as well as enhancing the Nissan GT-R's signature exhaust note.
Dyno testing has yielded broad gains of 15-22 AWHP on an otherwise factory equipped Nissan GT-R.
Weighing in at only 17.6lbs, the AAM Competition GT-R Resonated Mid-Pipe trims 12.4lbs of weight from the factory mid-pipe!! (factory weighs 30lbs, the AAM Competition non-resonated midpipe weights even less)
Available in both resonated and non resonated piping finish.
AAM Competition 3" Downpipe (W or W/O Cat)
AAM is proud to introduce our newest exhaust upgrade for the Nissan GT-R: the AAM Competition 3" Catalytic Converter Downpipes. Produced from highly durable 16-gauge T-304 stainless steel, the AAM Competition 3" Catalytic Converter Downpipes is an essential upgrade to optimizing your GT-R's exhaust system and vehicle's power.
With a turbocharged vehicle, power gains through exhaust flow is a basic concept - get the exhaust gases out as quickly as possible. AAM Competition 3" Catalytic Converter Downpipes will allow the turbo to spool faster, harder, and more efficiently – gaining new power. A secondary benefit from the additional exhaust flow after the turbo is lower engine temperature. Because we are evacuating the heat faster and with less resistance, there is less time for heat to build up.
The result is a noticeable power gain across the entire rpm range as well as the ability to support additional peak power.
AAM Competition High Pressure W/G Actuators
Want to run more boost? Here's your answer. The factory GT-R internal wastegate actuators are limited to approx 16psi - The AAM Competition GT-R High Pressure Wastegate actuators will allow your GT-R to utilize the full potential of the factory turbocharger and sustain boost. With the AAM Competition Catalytic Downpipes, AAM Competition Midpipe, AAM Competition High Pressure W/G Actuators and a boost controller, our customers typically make between 535 and 555awhp on the dyno.
AAM Competition Intercooler Piping Kit w/ Dual BOVs
AAM Competition is very pleased to introduce the AAM Competition GT-R Intercooler Piping Kit. Made from high quality, durable air-craft grade aluminum, the AAM Competition Polished Intercooler Piping Kit is another great bolt-on modification. By switching to an all hard pipe aluminum set-up, increasing the piping diameter in certain sections, smoothing out transitions, and adding twin HKS SSQVs, we were able to increase throttle response and overall engine performance, plus give the GT-R's engine bay a show car shine. The AAM Competition Intercooler Piping Kit comes with Twin HKS SSQV Recirculated Blow Off Valves.
AAM Competition Oil Cooler Kit w/Fan
We've quickly seen the GT-R go from a well mannered supercar to a 600+hp 10 second monster with simple bolt on components. And although the GT-R features an oil cooler from Nissan, as you increase your power, the demand for cooling increases. Time Attack, Drag, Road Race and Spirited Street Driving all will benefit from increased cooling.
Details & Advantages:
-High Capacity/High Efficiency Racing Core
-Increased Core Size with a HUGE increase in fin and row count over OE
-Features Remote Mount Puller Fan - Provides constant airflow draw through the core
-Mounts in Factory Location using factory hardware; Retains factory ram air shroud
-Fan can be wired to run constantly or with a switch
-Features AAM CNC machined VR38DETT block adapter fittings and non-abrasive/non-corrosive oil line.
AbrasiveRaysive
Sep 20, 2021 02:29 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
